Question about Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum
Red light came on on my dirt devil mvp swivel glide. could you help. thank you.
  • 126 Answers
SOURCE: Dirt Devil vacuum sucks... figuratively
Well, I guess your visitors have come and gone, but the vacuum remains the same. It sounds like you have a broken or worn belt. The belt should be changed once a year (approx) and can break if something is picked up that jams the brush. It is also possible that you have something obstructing the vacuum inlet at the brush housing.
If the belt is worn, it can still look o.k., but won't have the tension to turn the roller when it engages the carpet. I suspect the belt is your trouble.
Posted on Mar 30, 2008
  • 566 Answers
SOURCE: dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Posted on Nov 02, 2008
galati2k
  • 281 Answers
SOURCE: Dirt Devil Swivel Glide
look on the underside where the brush roller is and unplug it first then try to turn the brush roller by hand,if it turns real freely the belt is broke.you might have a clog at your intake hose at the bottom its the clear looking hose that goes from the bottom and comes up the back.if the belt is broke before you put a new one on clean the motor shaft there might be some old belt rubber on it ,otherwise the new belt won't last
Posted on Apr 09, 2009
  • 10 Answers
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
Posted on May 26, 2009
  • 430 Answers
SOURCE: I need help replacing the belt on my Dirt Devile Swivel Glide.
Look for a silver motor shaft behind the brush roll but in line with where the belt sits.
If the shaft is blackened with burned rubber or rusty, it should be polished with wet dry sand paper, XTRA Fine. Then install the correct belt onto the shaft and brush, using the brush to stretch the belt forward so the brush can drop into it`s housing. Buy belts 2 at a time. They only break when you need them most. I hide my spare inside the housing.
Posted on Sep 13, 2009
How do I get the bottom of off the dirt devil swivel glide
The bottom does not come off. If. You remove the screws the top cover can be removed to gain access to brush roll, belt and motor compartment
Feb 15, 2015 | Dirt Devil Vacuums
My dirt devil bagged upright(swivel glide) wont turn on..light on
  • its clogged that is what the light shows is that if your vacuum is clogged then that light will come on and it will shut off, i have the same vacuum and mine does not come on cause its not clogged
Mar 09, 2010 | Dirt Devil SwivelGlide Bagged Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Dirt devil swivel glide - no suction
Nov 02, 2008 | Vacuums
I have a Dirt Devil Swivel Glide Vac with a broken belt. I have purchased the correct belt(#4).The bottom is off and I cannot tell where the belt connects to. Please help. Jann
it connects to the left side with the little metal rod sticking out.then connect to the wooden roller. in the space without the brush on it. roll the wooden piece to check if everything moves. then put back together.
Aug 27, 2008 | Dirt Devil Vacuums
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
Dirt Devil 12 Amp HEPA Filter Vacuum Vacuum Logo
74 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
