Have upgraded from xp to windows 7 is there a driver
  • 25 Answers
You can download and install the drviers that are available from the website of your computer manufacturer. Please check the computer manufacturer and browse in their websites and download the required drivers that suits for your computer Model.
Windows 7 is bundled with all the required drivers for any computer. Every Hardware device will get the required drivers installed while installing the Windows 7 Operating System. These Drivers drivers are assigned by the Microsoft. However, Unassigned drivers can be downloaded depending on the computer Model.
If you have internet connection in the computer that has the issue, then you can run the Windows update to keep your computer upto date.
Posted on May 28, 2011
How can I get a driver download for Windows 7.
The easiest way is to go to the manufacturer website and look under support for an upgraded driver. I will tell you that when where I worked upgraded to Win7 we had many HP scanners that would not work with 7 and there were no drivers available. If you run into that then start looking on the manufacturers forums to see if someone has written a homegrown driver.
Aug 16, 2016 | Office Equipment & Supplies
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
IK Multimedia Production IK Multimedia Amplitube 2 Jimi Hendrix Edition Crossgrade/Upgrade (AT200UJHIN) won't play right on windows 7
Have you tried to use XP mode in Windows 7? In Windows 7 you can install XP mode and attempt to run the software from the virtualized environment. For the download for XP mode on Windows 7, go to this website: http://www.microsoft.com/windows/virtual-pc/download.aspx
Another thought that I have is that in Windows 7 - have you searched for an updated signed driver for your sound card? Depending on the model of computer you own - you can usually find the signed drivers at the manufacturers support website. Sometimes, changing the driver you are using for your sound card can also effect how your sound interfaces with different programs.
I hope this bit of information helps!
Nov 12, 2011 | IK Multimedia Production IK Multimedia...
Why does if i upgrade my laptop to windows 7, it can't be activated? and why does my drivers where not compatible with windows 7?
Because the laptop is made before Windows 7 is made. If you try to look at the drivers website (Click Me). There is only Windows XP and Windows Vista drives that is available not Windows 7. refer to the figure
Jul 22, 2011 | Dell Latitude D630 PC Notebook
How to uppdate from Windows Xp into Windows7 I
Well, it depends on your computer specification because every operating system has it own hardware requirements. Before upgrading to windows 7 make it sure your motherboard support the windows 7 operating system. In your case your motherboard supported by the windows 7 so when upgrading rather formatting your computer you must have the windows 7 installer. Then follow this video tutorial on how to setup your computer to windows 7. Before formatting you must have to back up all your data or files saved on your hard drive. Have a nice day
May 27, 2011 | Intel Motherboard
Problems downloading from camera using windows 7 - error message say windows XP required - is it possibel to upgrade software to be compatible with windows 7
If your OS is Win7 64 bit, then incompatibility must be occur because Windows XP use 32bit Operating System and driver software usually only special for each OS (x32 or x64). About upgrading the software, how will you upgrade while you can't even install the basic software in your PC ? The choice you have is find another driver that compatible with your OS, you can search via Google, and I hope you are lucky enough to get it available or even free to download.
If you still want to upgrade, then the Windows7 is the one to be upgraded so you can use XP Mode system. You must have Windows 7 Professional, Enterprise, or Ultimate to run Windows XP Mode. You can visit microsoft.com for details.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Fuji FinePix F810 Digital Camera
I have upgraded the O/S to Windows 7. Impossible to load a work:(
Try installing the driver in Compatibility Mode. Right Click, the main .exe, then simply choose compatibility Mode for XP SP2
May 26, 2010 | EzKey EZ-8000 Smart Office Keyboard
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
