Question about Troy Bilt Tb70ss Gas Trimmer
Need to replace primer bulb. whats the part # and the spark plug #
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
The primer and hose assembly is PN: 791-683947B
or 791683947B
Here are the primber bulbs if you just want the primer bulb:
http://www.jackssmallengines.com/primer_bulbs.cfm
^--You will have to know what Carburetor is installed to order the correct one.
The owners manual for the TB70SS is here:
http://www.hammerwall.com/tempmanuals/L0512013.pdf
The spark Plug is PN: 791-610311B
or 791610311B
Thanks for choosing FixYa,
Kelly
Posted on May 28, 2011
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
How do I replace a fuel primer build on the Stihl BR600 blower/
Disconnect the spark plug wire from the spark plug and ensure it can't come in contact with the spark plug. Removal of the spark plug wire removes any possibility that power can be supplied to the engine of the blower during the repair.
Remove the screws that hold the air filter cover in place. Remove the air filter cover and air filter. Remove the air filter housing from the side of the machine. Removal of these components allows you access to the primer bulb, fuel line and carburetor.
Repair Procedures for Stihl BR600 Backpack Blower Primer
Nov 03, 2014 | Stihl BR600
Not getting gas - wont start
carburettor dirty ,primer bulb has hole in it, or at worse the inlet from the carb.to the cylinder head cracked. hope this helps
Feb 12, 2014 | Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Spark plug has no spark
Check the on/off switch, Check the timing gap between the flywheel and ignition module.
Jul 29, 2013 | Garden
How do you check for spark on a McCulloch 3200 Chainsaw?
They make a handy dandy tool for that. If you are going to work on/with small engines, it's a good investment.
This one is similar to the one I use -
Small Engine Tool for Briggs Stratton Kohler Tecumseh Spark Tester eBay
Dec 29, 2017 | McCulloch Garden
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
Lawn mower wont start when I pull the cord, it has plenty of gasoline.
Does it have a primer bulb? Does the primer bulb have a crack in it? If it does it won't do its job, needs to be replaced. Is the plug good? Does it have spark? How old is the gas? If it was in the tank for a long time, it may not be potent enough to fire. Plugs are inexpensive to replace, and can do wonders.
Hope this helps.
May 05, 2010 | Troy-Bilt Pony Garden Tiller
My Poulan Pro weed trimmer SM132 does not run. I replaced the primer bulb and spark plug and it ran fine for 10 minutes. Now it will only start with the choke on and dies immediately. It will not start...
The primer does require two lines attached as it is a Walbro style primer. All four SM132 models uses the WT628 Carb. Since the trimmer ran 10 minutes then you have got all the lines connected right. Mostly you got trash in your carb or it simply needs rebuilding as the diaphragm may have pin hole in it or the check valves are worn out. Depending on the age and use of your unit you may also have a sticking piston ring.
Aug 23, 2009 | Poulan Garden
Troy Bilt Tb70ss Gas Trimmer Logo
404 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
