Question about Dishwashers
The door lock is locked and now the door will not shut.
    Master:
  • 414 Answers
Make sure the power is off to the dishwasher at the breaker panel and using a
pencil or some small stick, insert it in the latch on the door and depress the
lever mechanism. This should release the door latch and allow you to move
the handle back to the proper position.
Posted on May 28, 2011
My Lexus es300 2001 Doors get locked after i shut the even when I do not Lock the door. When I reopen the door with the key, the alarm goes up and will not stop until I start the engine again
Check your owners manual,you may have different programming modes for the locks ,such as automatic locking time etc.If you have different lock programming,reset the locks to a program you like.Also,sometimes just the action of shutting the door makes the lock button contacts touch inside the button and the doors lock,try shutting the door softly to check for this.
Jun 18, 2017 | Lexus Cars & Trucks
Door lock is on but door is not shut, how do I get it unlocked so door can go shut
Unplug the oven for 5 minutes and see if the lock resets.
Nov 22, 2016 | Ovens
Bosch Maxx6 washing machine. Shut door,rinse button flashing but door not lock so start button will not start circle
look at the place where the lock locked in the door the metal pinns could be broken or covered with erosion or something. De door lock makes no contact with the receptor.
Mar 04, 2015 | Bosch Washing Machines
1995 ford futura doors wont lock
Inside the door is an electric motor that pulls the door lock down to the locked position, either the rod has come off to the door latch from the door lock motor or the motor has failed. Remove the door panel and check it for power when the button is pressed for the power locks, if it gets power then it is most likely the motor that is the problem.
Nov 01, 2012 | Cars & Trucks
2000 caravan the door locks ingage when in motion how to shut off
when you get in the van lock the doors before you "take off" and that should fix that sound you hear when the doors lock. by locking the doors before you leave, the van will tell itself the doors are locked. i know having to lock the doors every time is a hassle, but this should solve your problem.
Aug 11, 2012 | 2000 Dodge Caravan
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
I was locked out of my 2007 silverado.
There is a feature called "delayed locking". If you get out of your vehicle and the keys are left in the ignition when you manually lock the doors with the door lock switch, the system will warn you the keys are in the ignition and do you really want to lock the door.
If you manually lock the door with the door lock switch a second time and shut the door, the locking system will lock all doors in 7 seconds and lock you out.
You can disable the feature through you DIC or have your dealer do it for you. The instructions are in the owners manual if you would like to try it.
Hope this helps, let me know.
Best regards,
Apr 08, 2009 | 2009 Chevrolet Silverado 1500
Door open!
i had the same prob..and the cure was to change the bushes on the motor.its been fine since
Oct 28, 2008 | Whirlpool AWM6100 Front Load Washer
Door lock
try crc into lock
if no good replace door lock
Nov 16, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
