Question about Exercise & Fitness
I get a error code E09 on my Roger black treadmil jx-285! Can anyone help me please? Tried everything
  • 1196 Answers
SOURCE: i have a roger black treadmill the power light is
All powered treadmills have a breaker. The purpose of the breaker is to prevent a power surge that might damage the treadmill motor. Check the circuit breaker on the frame near the power cord. If the reset/off circuit breaker has tripped, wait 5 minutes and then reset the breaker by pressing the switch in. That should fix the problem.
Posted on May 11, 2011
SOURCE: roger black gold treadmill
Me neither. I can switch it on but cant get it to do anything :(
Posted on Dec 01, 2009
SOURCE: looking to find a user manual for Roger Black Gold
Hi I just found out where to get the manual ring 0845 6000 464 they should be able to help - ive been trying to get a manual too and had success at last from the Reebok Tech team, they were great and fast too! Gd luck!
Posted on Mar 24, 2010
SOURCE: how to lubricate roger black gold treadmill and with what
We too have a RB Gold Treadmill and we too can't find the instructions or the lubricant it came with. I remember the instructions saying to lubricate every 100 hours and to use the tool to keep the belt from getting baggy. I remember it said to tighten a little at a time and to check the belt stays central when it's running. The tool is an allen key and the belt is tightened at both sides of the belt at the end of the platform at the back. If the belt isn't central it needs more adjustment on one side.I seem to remember the lubricant is silicon based. If anyone can confirm or correct this I'd be grateful. Thanks Chris.
Posted on Apr 03, 2010
maxtreadmill
  • 832 Answers
SOURCE: my roger black treadmill keeps tripping the
This could be a lubrication issue if this treadmill has never been serviced or worn belt/ deck. The last thing I am thinking about is if the unit is turned on with nobody on the unit and trips the the breaker then you have a shorted lower board.
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt.
4. Lift the belt and use approximately ½ of the tube by squeezing the lube in the walking area lengthwise. Move to the opposite side of the treadmill and repeat using the remainder of the lube. Use all of the contents of a single container during application. Do not put any lubricant on any surface with which your feet make contact. The lube will spread evenly in the next step. Do not perform this step by hand. The lube is usually not harmful to the skin but has the potential to permanently stain fabric. 5. Adjust belt tension and centering following your owner’s manual instructions if you have loosened the belt to clean. LOOSENING THE WALKING BELT IS NOT NECESSARY JUST TO APPLY THE LUBE. Start the treadmill at 2-3 mph and allow to run for 5 minutes without walking on the treadmill. Check centering carefully and adjust as needed following your owner’s manual instructions. Using your treadmill’s handrails and safety switch for safety and support, walk on the treadmill at 2-3 mph. CAUTION!!! BELT MAY HESISTATE. THIS CAN CREATE AN INJURY IF BELT IS NOT PROPERLY TENSIONED! Within 5 minutes the lube will be preliminarily walked in to the backing of the belt. Damage and/or injury may occur if the belt is not properly centered and tensioned by using your owner’s manual. 5. CAUTION: Do not run on the treadmill until your are certain the belt tension and centering is correct according to your owner’s manual specifications. Make certain that there are no friction.
Go on E-Bay you may purchase a kit or a single application all of them are a silicone base lubricant so don't worry about which is the best. The application will also determine if the visual inspection and cleaning did the job and if the breaker trips then you have a belt and deck issue.
Posted on Jul 19, 2010
I have a roger black treadmill and E09 appears on the led screen. Nothing responds when I press buttons
E9 treadmill error: connection error
1. Check all wiring from Base to console.
2. If E9 still there replace controller
Jul 21, 2016 | Exercise & Fitness
I have an everlast treadmill Jx-269e showing error e09. Any idea what to do about that please?
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you65723e8e-6bcc-4a02-900e-e9fa117bb428.gif
Apr 03, 2013 | Exercise & Fitness
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
Problem with my Rogerblack treadmill
i av gold treadmill model ag10302 and need 2 get mains lead
May 17, 2012 | Exercise & Fitness
I'm trying to help my friend move her bedroom round as she has new wardrobes coming, and we cant get her roger black treadmill out of the room with out dismantling it, but she has lost the manual so I need...
I have a Roger Black Treadmill & it came in 1 piece ready to go. There is no way to dismantle the one I have. Not sure if there are multiple models but I have only ever seen 1
Aug 31, 2010 | Baby Gear
Roger black treadmill.
i can repair or supply any roger black parts that you would need. contact me on 01706 371711
Jan 27, 2008 | Baby Gear
Exercise & Fitness Logo
536 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
