Question about Casio G-Shock DW6600C1V Wrist Watch
I just changed the battery on my G Shock DW 6600 but a gold spring dropped out from inside and I don't know where to put it back and when I put the cover back on the alarm sounds constantly. Please help
SOURCE: I had the battery in
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Posted on Apr 24, 2008
SOURCE: I had my battery replaced
There are two internal springs that contact the back cover of the watch through an insulator. The alarm nor chime will work if they were not put into their proper locations or were omitted during reassembly.
Posted on Jul 01, 2008
escapement
  • 2334 Answers
SOURCE: Model & spring issue with an ol casio G-Shock when replacing batt
This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
Good luck
Arthur
Posted on Dec 17, 2008
SOURCE: shut off hourly alarm on g-shock
Okay I have this module so here goes.
Start from your regular timekeeping mode (use lower left buttin to cycle through until you get to the normal time display).
Press 'mode' button (lower left) once. You are now in alarm mode.
Press lower right button to cycle through the alarm modes. The cycle goes: hourly beep on, timed alarm on, both on, neither on. You will see the corresponding icons (a ripple icon for hourly beep and and a bell icon for the alarm) appearing/disappearing in the top left of your display as you cycle through. So if you are in hourly beep mode now you probably need to press that lower right button 3 times to get to 'neither' alarm being on.
Press lower left button to return to normal display.
Hopefully - enjoy the peace!
Posted on Mar 30, 2009
SOURCE: spring poppedout on dw 6900 g shock. need a
This happened to mine, couldn't get a spring anywhere. But managed to fix it by using a staple which I cut to size, Works fine now.
Posted on Nov 12, 2009
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
Casio dw-290-t, springs came out when changing battery, I know wher 1 goes not the other?
The smaller spring is steel with gold plating. It goes into a hole that is near the outside diameter of the battery. You must remove the outer steel retainer to see the hole. Leave the other parts assembled. They will be loose at this point. When you look inside the hole you should see a gold bottom which is really a contact on the board. Insert the spring with the smaller diameter end into the hole. If you have the correct hole then the larger end of the spring will fit just perfectly. Assemble the outer steel retainer. Finish assembly.
Next time you replace the battery only remove the battery strap and leave the other parts intact. Good luck.
Jun 22, 2012 | Watches
Dw-6600 need a manual for my watch, where to find one on-line
Hi.
Please click on the link below to open the manual for your Casio G-Shock (DW-6600 module 1199):
Casio owners manual.
Regards.
Ginko
Sep 08, 2011 | Casio Watches
Spring poppedout on dw 6900 g shock. need a
Oct 23, 2009 | Casio G-Shock G7000D-8V Wrist Watch
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Good luck
Arthur
Dec 13, 2008 | Casio DW290 1V Classic Alarm Chronograph...
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
I had my battery replaced in my Casio G Shock DW -6800. Since then the beeps and alarms are not working. Is there some sort of reset button he forgot to press?
Apr 24, 2008 | Watches
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock DW6600C1V Wrist Watch Logo
703 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
