Question about LG Cell Phones
Kindly help me with my problem about my lgkm555e. when i charge it the unit will become hot easily and the charging icon doesn't move at walang 5 minutes low bat na.
    Genius:
  • 1,622 Answers
Battery draining fast?
Hi, most causes of battery cell running down very fast is because the problem is not from the battery, but from the cell phone it self.
Some times a phone will just start malfunctioning due to when something happens to a phone earlier and no action was taking during that particular period in time, it might make the cell phone to malfunction later on.
The problem of the phone is an IC chip inside on the board of the cell phone that has been damaged that is making the battery cell to discharge.
You will need to replace the IC inside the phone.
The more you don't repair the IC on time inside the phone,you will keep on buying more batteries.
To fix or replace the damaged IC, you can contact an expert on phone repair for help.it's a little bit technical to handle.
Hope it helped.
Thanks for using fixya..
Posted on May 28, 2011
Charging socket for viewpd 7 bad contact when charging
No The socket has become worn or bent needs to be serviced. Or perhaps a new charging cord, if you have not tried that already.
Jan 24, 2014 | ViewSonic ViewPad 7 Multitouch tablet
I have htc windows 8x phone. My phone wont charge! i plug it in and the red charging battery icon doesn't appears, but it wont turn on no matter how long i charge it. i just got my phone 5 days ag
I think you have damaged your charging pin in the phone by mistake either by dropping the phone or while taking the cord out or inserting. I think the best way to get this fixed will be to go show it to the store that you bought it from/microsoft store. Hope this helps. All the best.
Mar 11, 2013 | HTC Windows Phone 8X
Charger unit on my zte android doesn't work how else can i charge my phone battery
1) use another charge phone and 2) use the charger USB in the computer, see the diagrams attached.God bless you1_30_2013_8_06_08_pm.jpg
Jan 30, 2013 | Cell Phones
Please help. My Fujisu Lifebook S7020 does not charge. There started to be a problem charging it that i had to move the tip around but now its just dead it doesn't charge it desn't work it's...
It seems you have a problem with your power adptor, which gets easily broken wires, due to usage. If you have a multi tester and possible if you can check the output voltage of your adptor, which should give 19 vdc according to the requirement of your laptop. Try to get power adptor of same kind and check, if it does work, repairs can be done to the power supply, if you can find a tech for this.
Sep 01, 2011 | Fujitsu Siemens LifeBook S7020 Notebook
I pod displays "connect to power" then shows
It sounds like your battery is bad. They can be replaced readily easily. Batteries an be found on eBay for as little as $5 and directions to replace it can be found here:
http://www.ifixit.com/Browse/iPod
Jul 26, 2011 | Apple iPod MA446LL/A MP3 Player
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
My cell phone doesn't charge, gets hot, Bluetooth
What type of phone are you seeking help for?
Jun 08, 2011 | LG Cell Phones
System becomes very slow at the time of charging the laptop
Hello. Your battery most likely needs to be replaced. That said, if possible have the laptop's charging system tested also. Joe
please rate my answer as very helpful. thanks.
Apr 25, 2010 | HP Compaq 6510b Notebook
Cell Phones Logo
48 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
