I have a Sound Lab GO56C turntable with usb connection - my ACER (vista) laptop cannot connect - any advise??
Riziel
  • 116 Answers
SOURCE: USB Port Recognition
You must Look on your Desktop Locate
My Computer
Right click on My computer
click on Properties
Go to the Hardware tab
Click on Device Manager
Locate your USB Ports which are probably at the bottom of that list
If there is an X over the USB Connections you must right click to enable them
The other solution is to plug up the device and follow the above steps
I sensing that this device did not have drivers that were downloaded to your system.
The other thing is try to plug the device into another computer to see if it is reocginized by the other computer. If it is reocognized you know it is not the device. It is software related
Posted on Nov 26, 2007
SOURCE: cant get sound via hdmi connection from acer 6920g laptop
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Posted on Jan 19, 2009
richin29
  • 29 Answers
SOURCE: Acer 5520 wont connect wirless
Try unistalling the wireless driver and then download the right driver for your wireless card from http://support.acer-euro.com/drivers/notebook/as_5520.html
it might work!!
Posted on Feb 05, 2009
  • 221 Answers
SOURCE: Unable to connect mouse to acer laptop
Before you connect your wireless mouse USB adapter to your laptop you'll need to install the software first, after the software is installed follow the steps to connect the wireless mouse USB adapter, this will keep the instalation wizard from popping up.
Posted on Apr 01, 2009
shredivya
  • 71 Answers
SOURCE: USB ports on my laptop not connecting
You can try uninstalling USB root hubs from device manger and restart the unit and check,
Posted on Jul 03, 2009
How do i connect an ion ttusbos turntable ?
I have one answer, first buy a new laptop instead of an ancient one.....
Sep 07, 2014 | Audio Players & Recorders
How do i connect ION USB TTUSBOS turntable to acer laptop ?
You connect the turntable by a USB port on the laptop. It should be recognized as a USB sound device that can be used by any program. The program Audacity is a free sound recorder and editor.
Sep 07, 2014 | Computers & Internet
Connect optimus lab 1100 to macbook
The type of computer is not relevant. This turntable provides output at nominal "line level" and can be connected to your MacBook with a properly shielded audio cable through the audio input.
For best results, you might want to disable automatic-gain-control (AGC) in the "Sound" preferences pane in the "System Preferences" panel, and set the level manually such that the input does not overload.
As I mentioned above, the signal level is nominally "line level", and that can mean very different things depending on context. You might find that using a passive volume control (potentiometer) between the turntable and the computer's analog-to-digital converter can greatly improve the quality of sound.
Jun 20, 2014 | Apple MacBook Pro Laptop Computer with...
Bad sound quality
You cannot connect the turntable via a microphone port. You need to connect via a USB port. If you have not got a USB port to connect it as the others are in use, you can buy an extension USB socket which, will allow you to put more devices via one USB port.
Sep 04, 2013 | ION Audio Vinyl Recording Turntable
Ionusb turntable not connecting to computer
its a driver issue. try to connect it to another unit that is using another os, or check manufacturer site for driver support
May 05, 2010 | ION Audio iTTUSB Turntable
How do i record music from my djm 700 to my laptop
Has your laptop got an audio input socket? If it has you can plug your turntable into that. You might need some kind of adaptor plug to connect, but your local electronic shop should be able to supply you with it. When you have the sound going in you will need software to record it, I would recomend Magix Audio Cleaning Lab. This will allow you to record the signal, plus being a record get rid of the clicks and other noise. It will take a bit to get used to but you will soon learn. You can get it fairly cheap on Amazon.
Oct 23, 2009 | Pioneer Audio Players & Recorders
Connecting NAD 2600a amp.
Never connect incompatible connections. Speaker outputs are for speaker inputs. Period.
The various inputs on this or most any amp are for Line Level signal with the exception of anything explicitly labeled "PHONO" as that would be for a non-preamplified turntable ONLY.
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used in the (assumed) preamplifier that fed this amp.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use the Lab In's UNLESS you have a turntable source.
Aug 22, 2009 | NAD Audio Players & Recorders
I'm not getting sound with my Ion Turntable
Ater spending several hours trying to correct the problem I replaced the USB cord and it worked.
Thank you for your reply.
Oct 06, 2008 | ION Audio iTTUSB Turntable
My lab top is play music with sound
download sound drivers from the laptop manufacturer website
or make sure that you connected the speakers properly.
Aug 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
No sound coming from computor speakers while recordind from lp's.
Hey plaz21, I came here looking for the same answer, and when I didn't see any, I just unplugged the USB from the computer and it played!!
You have to export what you recorded to mp3, then unplug the turntables USB from the puter, and "Voila!"
Jan 15, 2008 | Gem Sound DJ-2100 Turntable
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
