Question about Cisco WAP4410N (WAP4410NLA) Pre80211n Wireless Access Point
Setup and cinfigure cisco wap4410n wiireless -n access point with repotec router ( windows 7)
4 Suggested Answers
SOURCE: Need Setup CD for WAP54Gv.2 wireless router
need solution for my wireless is not connected
Posted on Sep 17, 2008
SOURCE: Ip address for clients using autonomous cisco 1130ag witout dchp
the cisco1130ag will provide ip addresses and serve as a DHCP server for your laptops...
You still need an IP address for your 1130ag so either your ISP provides you a static ip that you can put in the 1130 or if your ISP provides dhcp then you should be able to plug and play with your 1130ag
Posted on Mar 12, 2009
SOURCE: I'm trying to configure my
Network settings on your computer
right click on lan network and properties go to ipv4 properties and use the following.
IP address 192.168.1.2
255.255.255.0
router defaut in the default gateway settings (mine was 192.168.1.245)
enter that again in the dns primary (dont worry about the secondary)
plug an ethernet cable to your wireless router and type in the default gateway.
that will get you to your logon page.
hope that helps
Posted on Jan 11, 2011
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
What is default IP of CISCO WAP4410N WIRELESS ROUTER
Hello Anonymous,
The default IP address for the router you are asking about is 192.168.1.245.
The user manual direct from Cisco can be found at the link below.
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap4410n/administration/guide/WAP4410N_Admin_Guide.pdf
Take care and have a wonderful night! -Alex K
Jun 10, 2014 | Linksys Cisco Small Business WAP4410N...
How can I get a PIN for a Cisco WAP440N W-less access point?
Here is a link to the manual.
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap4400n/administration/guide/WAP4400N_V133_UG_Rev_B_web.pdf
If this is a device you received used, You will want to follow the factory restore procedure.
I hope this helps you out. Please comment if further assistance is needed.
Oct 17, 2013 | Linksys Cisco Small Business WAP4410N...
Configuring Wi-Fi Protected Setup
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 24, 2012 | Linksys Cisco Small Business WAP4410N...
My cisco wap4410n won't let windows 7 connect
Dear Romo
i have had lot's of problem with the WAP 4410N
the usual solution was to reset the Access Point
and in some case you have to reset it to factory default and set it up again try change the channel of change the location of the Access point for testing only
yesterday i face a problem with WAP4410 that the laptop gets IP but smart phone /tablet doesn't connect stack when getting an IP with static IP the devices connected
So what i did ,I went to the market and buy a new AP NOT Cisco brand
Cisco devises i lost truest on it
Abdullah Al-Ahmadi
System and Network Eng.
Mar 26, 2011 | Cisco WAP4410N (WAP4410NLA) Pre80211n...
How do I reset WAP4410N router back to factory defaults ?
There should be a reset button to the right (the back facing you) of the antennas on the back, press that for 10 seconds to restore back to factory default. You may also go into the the web based control panel of the router and set it back to default.
Dec 06, 2010 | Linksys Cisco Small Business WAP4410N...
I'm trying to configure my Cisco WAP4410N Wireless-N Access Point and i cant access the login page to do it. My IP is already set to 192.168.1.# so i thought i would be fine but it still doesnt work
255.255.255.0
hope that helps
Nov 03, 2010 | Linksys Cisco Small Business WAP4410N...
Cisco WAP4410N (WAP4410NLA) Pre80211n Wireless Access Point Logo
242 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
