Question about Electrolux Washing Machines
We have an electrolux EWF 1090 and the door will not open after the cycle has finished.
    Brigadier General:
  • 6,277 Answers
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 28, 2011
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
Electrolux ewf 1090 , door lock fried, replaced PCB and door lock , not going
Hello - From what you have described it sounds like the washer could possibly have a communication problem with the control board not responding. Since you have already replaced the door lock, I would strongly suggest contacting a professional to accurately diagnose the unit.
Sep 28, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux EWF 1495, spin does not work in quick60 cycle
it,ll will be a circuit board fault, probally the motor inverter board there is 3 pcbs in this model.
May 27, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
