Question about HP 5502 CRT monitor
I have my HP 5502 CRT monitor. Which gives me trouble. The display can be fade and shows muti colours of the object. When I hit on the head of the monitor it comes to normal for few minutes after that it again goes to that bad stage. Please help me in this regard.
  • 336 Answers
The datacable of your crt monitor to CPU area have problem maybe loose contact to your VGA card.just double CRT monitor cable to CPU area.
Posted on May 28, 2011
Display problem power ok
This is going to be beyond economic repair as it is so old, you will need to invest in a LED monitor which propabably cost less than trying to repair such an old monitor, in fact i do not think any body will even want to repair it.
Feb 27, 2014 | HP 5502 CRT monitor
L750 block of colour on bottom half
Your lcd screen is going bad. It's either the lcd screen or the video card inside the computer. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok then your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same as your original monitor then your video card is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Jun 08, 2012 | Toshiba Satellite L750 Notebook
Hp g6 screen fades out
The lcd screen or video card inside the computer is going bad. To isolate the problem connect an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to connect to the laptop.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays without a probem that proves your video card is ok and your lcd screen is going bad. If the external monitor displays by fading in and out like your lcd screen, then your video card inside the computer is going bad.
May 25, 2012 | HP Computers & Internet
I have A Compaq monitor,edited
omg an antique monitor
a relic CRT monitor?????really?
is it really MV320????or a typo.
MV500s are CRT (heavy cathode RAY TUBES)
you model is rare now, no photos of it by you.so...
if not a CRT pig.
then it must be a flat screen monitor
the first ones, up to year 2010 used crapppy
CCFL back lamp tubes that are bad now. all are.
(unless never used)
call CCFL fail these ways.
dim.
white now yellow
dead.
blinks, or is intermittent,or strobes.l
the backlamps CCLF tubes are dead. all do that, or just die .
crt monitors
are junk and a fire hazard, trash it.
CRT fails more ways
sure dim,sure dead.
but it has 3 guns , RGB , red green blue.
the red gun loves to go weak first , red phosphors
are weak (a physics deal)
one trick (long long ago is to up the red gun levels, to compensate.
or lower Green/blue guns.
gun means "electron gun" deep inside the CRT neck
The CRT has even more bad effects, failed.
a huge endless list , if you want.we have it.
with photos
Jan 23, 2018 | Compaq MV 520 Monitor
My monitor is not displaying colours.... its only showing bit of blue and yellow colour.... please give me solution.....
CRT monitors can fade over time. try resetting factory settings and degaussing, if you have that option. If not, you need a new monitor. Buy an lcd.
Feb 18, 2011 | HP mx705 17" CRT Monitor
The colour of the monitor fades sometime and at that time the colour control switches in the front panel does not work.
the board that is connected to the control switches is going out. and the color fading sounds like something is wearing out. best solution is buy a new one, you can get a cheap one for like 120 to 150 bucks. LCD monitor uses alot less power than a crt monitor. so there are some benefits for this.
Oct 17, 2009 | IBM E74 17" CRT Monitor
My monitor displays bright green pixcells in the black areas of text and pictures .I have tried a different monitor (lcd also, no problem ) to isolate the fault back to the monitor.
some time we can see that of problem as screen convert in to voilat and green colour. it is called colour fade. assambaling parts is lose of bord and other. it can be correct by soilding by expert tech. it is more seen in old crt monitor. thanks
Jun 14, 2009 | ASUS LCD Monitor
24" CRT HP A7217A Monitor stopped working
hello sir your vertical or horizal IC damaged.......... thats why its showing multi colour ...... just do one thing sir.......... fit your new IC
if your problem not solved..... type in comment
Apr 29, 2009 | HP A7217A (White) 24" CRT Monitor
Monitor Fading
get a new one of hp no luck thear just by a bigger beter one thean kick the old one
Feb 02, 2008 | HP mx705 17" CRT Monitor
Monitor problems
it an hardware problem i would suggest u check the display i.c of the monitor
Dec 10, 2007 | HP mx705 17" CRT Monitor
Computers & Internet Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
