My power tripped the other day and when I remade the breaker the washing machine (hotpoint aqualtis aqxxd 169) has come back on but in Polish!!! how do I reset it to English??
    Brigadier General:
  • 6,277 Answers
(If no one else answers here is how to obtain a manual!)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 28, 2011
My Aqualtis AQGD 169 S keeps tripping the mains switch
Make sure you are on a dedicated circuit for this machine and that it is a 50 amp circuit. After that you may have a bad breaker switch which is pretty easy to fix. You also cannot rule out that one of your components went bad on your washer.
Feb 28, 2015 | Washing Machines
My hotpoint aqualtis aqxxd 169pm displays a blockage, we have cleared filter and checked pump is working, yet it still displays same message, and now when the power is on the drum wont turn.
Did you check the filter the pepellor sometimes can get something stuck in it. In one case i came across there was a hair go-go stuck in the pepellor.And also check the pipes at the back the cold water mains pipe going to the washing machine and the discharge pipe are not twisted or kinked
Aug 06, 2011 | Washing Machines
What does f12 mean on a hotpoint aqualtis washing machine aqxxd 169pm
Hi, I think the F12 Error means lack of water or water turned off, check that first, if water is turned on then turn it off disconnect the hose from the machine, then hold the hose in a bucket and gently turn on the hose tap to check if water does flow, if it does check the valve on the back of the machine, there is usually a small filter in there that can get blocked, these can be pulled out by a small tab on top of the filter using a pair of pliers, clean it and then put it back in reconnect the hose and turn the water back on, try the machine again, if its still the same it could be a faulty water valve that will need replacing.
There is another reason F12 could appear which is a faulty PCB or wiring harness fault, but generally the above should be checked first.
Here's a picture below showing an example of the valve with the filter in blue, you might just be able to see the tab on the filter.
Hope this helps.
Feb 11, 2011 | Washing Machines
Hotpoint aqualtis giving H20 error, looks like fill problem, but cannot see anything stopping the water flowing into the machine.
i have hotpoint aqualtis, it washes & empties but then starts flashing when ready to rinse. any suggestions?
Dec 04, 2009 | Washing Machines
My Hotpoint Aqualtis AQXXD 169 PM is adding time to the was cycle, taking longer to wash through the cycle? ant ideas?
the time is a generic time and will adjust accordingly as goes through programe-for example it allows a certain time to heat in the winter your cold supply may be colder so the machine needs longer to heat water-load size-if its adding more than 30 mins then check filter
Nov 11, 2009 | Washing Machines
Trouble shooting the hotpoint aqualtis aqxxf149pi flashing f08
my hotpint aqualtis aqxxf149pi make a funny grinding noise when it spins help please?
Jun 25, 2009 | Hotpoint Washing Machines
Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Nov 30, 2008 | Hotpoint Ultima WD72 Front Load...
Not spinning- F5 fault error Hotpoint Ultima
I HAVE A HOTPOINT AQXXD 169 PM WASHING MACHINE WE HAVE A FLASHING MESSAGE F5 WHAT IS F5 AND WHAT DO WE DO. IS IT IN THE INSTRUCTIONS SOMEWHERE??????? WHAT PAGE????
May 11, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
349 people viewed this question
Top Washing Machines Experts
