Hi i have a magnavox 42" plasma TV (model KM-42010P) that i received second hand without a remote and have been turning it on and off at the power button, was to be until i worked out the universal remote, when one day it wouldnt turn on. the red light is on but pressing the power button gets no response. i turned it off at the power when i turned it back on the light went green and it made the click sound as though a picture was about to display and then switched back off and the light went red again. i really hope there is a solution. i dont own any other television.
trintek
  • 111 Answers
SOURCE: Magnavox dvix player to ilo 42
what are the modelnumbers on your divx player and your tv? if you are using svideo inputs do you have your audio cables hooked up? have you checked the volume on the player to make sure it is not muted?
once you supply more info i can help you further, until then, check your cables and audio settings on your divx player. and make sure all connections are in the right place
hope this helps
trin
Posted on Nov 16, 2007
SOURCE: RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Posted on Apr 05, 2008
DOCTOR VIDEO
  • 131 Answers
SOURCE: No Picture On 42 Plasma
if you have no picture and power it is usually fixable x or y boards cost is around 395.00 for repair . for service center to fix
thanks doctor video since 1987
Posted on Jun 14, 2008
SOURCE: Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Posted on Aug 13, 2009
SOURCE: Soniq 42'' QSP424T keeps freezing
I have been repairing Plasma Tvs for some 3 years now and have found most of the problems caused are by Capacitors.Once again Soniq are no different to the others.The fault is on the main Video Control Pcb.Replace Capacitor C529 which is a 470mfd25v.This cap is mounted next to an inductor coil at the top middle of the pcb.This Pcb is the one which has the tuner and all inputs on it.
Good Luck AND PASS THE WORD AROUND. LET US KEEP THE SERVICE INDUSTRY GOING.
VIEWCLEAR VISION PL BRISBANE AUSTRALIA.
Posted on Apr 08, 2010
Key code 39716781 model km 42010p
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Unlock procedure to many popular brand TVs are given.
May 20, 2014 | Magnavox Televison & Video
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
Hi I am tring to find a MAGNAVOX TV KM-42010P remote control
Hello
Buy one COMCAST CUSTOM DVR-3 DEVICE Universa Remote Control. Magnavox is listed in its codes. Codes are:
0054, 0030, 0179, 0186
You will get its catlogue and all other details, about how to enter codes, and a colde list for different devices to which this remote can be used. OK.
May 03, 2011 | Philips Magnavox 27MS343S 27" TV
Lost remote can i still tune the channals
Hi, you can tune the channels of the Plasma TV without Remote Control. However, I suggest that you to purchase a new Remote Control of the same model number of the Plasma TV with any near by Plasma TV dealer.
Apr 07, 2011 | Samsung PS42B430 42 in. Plasma TV
My Magnavox 42MF231D 42" T.V
You may have a weak power supply. This would indicate one or two capacitors that are weak or bad. This model may be about 4 years now and this is a good indicator as these capacitors need replacing. The other problem may be the infared board in the TV that receives the signal from the remote may be a problem as well. I would certainly investigate my first thought. The latter is kind of rare. Thanks for asking and show a few hands of support.
Nov 29, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
I can't see my tv
You likely need to select channel three or four on the TV itself if you have any kind of box between you and the signal source (cable, antenna, satellite). Magnavox is a name owned previously by Philips and now by Funai. They may not have all the info from Magnavox and Philips but you could check their website to see if they have the instruction manual for download.
Look under 'Support'
Funai
Jan 20, 2009 | Philips E-Box FTR9965 DTV Receiver
ESA plasma TV model pdp 4294lv1 does not work
my esa plasma tv model pdp 4294lv1 has sound and i can switch the tv channels, but the color is blurrier
Jul 22, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Plasma T.V
you need to contact phillips,magnavox consumer service which should be 1-800 number or look under www.phillips.com then type in km42010p.
Dec 23, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
