Question about 3Com 4500 24-Port Ethernet Switch
I have two 3com 4500 26port switch and i want it to configure both giga port in load sharing (GigabitEthernet1/0/27 and GigabitEthernet1/0/28) - meaning i want it to configure LACP protocol. How would i do that in CLI configuration. can you give me the procedure on how it will be done? YOur help would be highly appreciated! And my question is, is giga port of 3com 4500 can be configure in LACP load sharing? and if it is a loop free capable? Thanks. Aris
4 Suggested Answers
fossilruins
  • 114 Answers
SOURCE: enter the switch configuration
page 22 of the 3com user guide for your switch talks about how to use the console cable and how to connect to your pc, I included the link below for your manual, if you don't have it:
http://support.3com.com/infodeli/tools/switches/baseline/3Com_Baseline-Switch-2916-2924_User-Guide.pdf
Posted on Jun 21, 2008
SOURCE: 3com nj220 central config error response from device
Found that the problem was in the installation of the service.
There were two .exe in the installation software, one labeled setup.exe and the other "3Com IJNJ Configuration Software.exe". setup.exe is what needs to be used and it will in turn call the other. I had opened the other directly.
Posted on Feb 11, 2009
motaro
  • 449 Answers
SOURCE: Uplinking Using Gig Copper
hello, use the plugin modules for the rj 45 connection port to uplink it.
Posted on Aug 04, 2009
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
3Com 4500 Gigabit ethernet switch hangs after 3 minutes. Has to be rebooted.
yes reboot and than it will run properly may be some load issue on your switch
Dec 14, 2010 | 3Com 4500G 24-Port Gigabit Ethernet Switch...
My 3com 4200 28 ports is restarting by itself many
Base from the description of your problem its only showing that some of the port on of your Ethernet switch is already getting bad and this usually happen on switch like this and eventually all port will go bad and will lead to the replacement of the device. With this type of problem you can first try to adjust the speed of your network card to 10 half duplex and check if that will correct the connectivity problem and if it does its just a sign that sooner or later the device is already getting bad and since its only a switch there's no firmware that we can load to it or even a reset button to bring the device back to its default settings.
Jan 27, 2010 | 3Com 4200 24-Port Ethernet Switch
How can configure trunk
not sure about the 3COM side, but on the Cisco side... go to the configure prompt, then the port that you need to trunk (int [interface name and number] and enter)
Once you are in the interface, use the following command:
switchport trunk encap dot1q
switchport mode trunk
Then make sure that the interface is not shut down, connect the switches together and (hopefully) the 3COM will negotiate to trunking... if not you will need to manually configure the 3com.
Hope that this helps!
Jan 07, 2010 | 3Com Switch 4500 PWR 26-Port...
3com linkbuilder TP/8 I bought a used 3com linkbuilder TP/8 and have no manual. Is this a wireless router? at the back there is BNC port. What is it for? Thank you
I am pretty sure what you have is an ethernet hub..not a wireless router. It would be used as a distribution site for a shared network. The BNC port is a connection for coaxial cable.
May 06, 2009 | 3Com OfficeConnect Wireless Router
Need address for 3com office connect hub
Here is the link tothe Officeconnect Hub8 (PN 3C16700):
http://support.3com.com/infodeli/tools/hubs/off-con/3c16700/manual.a03/dua1670_0aaa04.pdf
Thisdevice is unmanagable meaning you can not define addressing on hub nor can you configure routing on the hub.
Mar 18, 2009 | 3Com HUB OFFICECONNECT Ethernet 10MBPS TPO...
Feb 08, 2009 | 3Com NJ220 Networking Switch
3Com 3824
Download free version of HyperTerminal for Vista : ftp://ftp.hilgraeve.com/htpe/htpe63.exe
Make a new connection :
connect using COM1 (depends of your configuration)
19 200 bits/sec
8 data bits
No parity
1 stop bit
No control of flux
And push enter twice to display a "Login:" prompt.
Connect using default user/passwords : http://support.3com.com/infodeli/tools/switches/ss3/management/ug/setup.htm#13131
Regards,
AstroMan
Jan 14, 2008 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Link and activity lights on 3Com Switch ports without connection
Do the ports work when the cables are connect?  I did some re-search and this seems to be an ongoing issue with 3com switches.  It should not effect the use of the switch
Oct 09, 2007 | 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH...
3Com 4500 24-Port Ethernet Switch Logo
236 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
