Question about Toshiba Satellite L305-S5907 Laptop
My computer goes blank every time my charger is plugged in
    President:
  • 3,278 Answers
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on May 28, 2011
My asus notebook PC turns on and goes onto the asus loading screen but then goes blank!
Don't boot on the battery. Plug into wall outlet and try it. Your battery might have croaked or your charger is dead.
If that fails, when booting, tap the F8 key several times. This will take you to a diagnostic screen. Try a couple different options there like "safe mode" and "last good combination that worked."
Jan 24, 2015 | ASUS Computers & Internet
Why laptop screen goes black after plugging battery charger?
Try another charger and then see or it might be a power options issue
Try this
SOLUTION: If you have a second computer, use Remote Desktop by choosing 'Run', type 'mstsc', type the name of the computer with a black screen, and connect. After logging in, open 'Control Panel', and choose 'Power Options'. On the left panel choose 'Choose when to turn off the display'. On the row labeled 'Adjust plan brightness', under the 'Plugged in' column, turn up the brightness slider.
Aug 10, 2014 | Sony SVE15135CXS - VAIO E Series...
My 7 inch irulu tablet does not charge
Try a different charger that is capable with your device, check battery, or reset if you can. Luck to you
Jan 04, 2013 | Tablets & eReaders
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
When I plug my nuvi 260w into car charger, the screen goes blank with a picture of unit hooked to computer. I cant use the GPS unless I unplug from charger
Sometimes this happens because the plug of the charger is not fully pushed into the back of the satnav. It feels like it is but it's not. Pushing it in further may solve your problem.
Jun 11, 2011 | GPS
When l unplug xs20-006 from the charger the screen goes blank,changed power settings but still goes blank ?
When you plug the back in, does the display come back on or does the laptop need to be powered on again?
If you need to power on again, your battery is faulty.
Feb 10, 2011 | Computers & Internet
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Notebook goes blank
your battery may be getting to weak to work.
try booting without the battery.
Apr 26, 2008 | Computers & Internet
Nano does not work-blank
sounds like it needs to be recharged. plug it into the wall charger or your computer and do not disconnect until it tells you that the charge is complete... this takes time and disconnect it from the computer by dismounting it before disconnecting so not to cause problems
Jul 06, 2007 | Apple iPod nano
Toshiba Satellite L305-S5907 Laptop Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
