Question about Canon Pixma MP500 All-In-One InkJet Printer
Service error code 6A00 Have disconnected power to and reconected but still cannot print a document.
  • Canon Master
  • 821 Answers
This error refers to the sheet feeder unit. there is nothing you can do to correct it but fit another sheet feeder. To be honest you would be far better to replace the machine as only a trained Canon engineer would know how to do this. there is a critical alignment proceedure to follow and if not done correctly first time it will strip the gears teeth off the new sheet feeder. i am one such engineer and i have wrecked a couple of sheet feeders myself. ughhhh
Posted on May 28, 2011
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
My CAnon MP 610 has a service error 6A00. What is
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 25, 2010 | Office Equipment & Supplies
6A00 Error code? I reset, checked for jams, etc, but no results? Any clues? It is a MP830 Canon, with a bit of printing time, probably several thousand total documents by now. The error code just came on...
OK this is old but you may look back
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Dec 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Service error 5c10, error code 6a00 wored
6A00 is the error when the purge assembly is broken or jammed. You need a shop to install a new one since the entire print engine has to come out to replace it.
Dec 04, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Service error 6A00
It looks like the print carriage was stuck. Turn on off the printer, manually move the ink cartridge back and forth a few times, look underneath for dirt or small piece of paper (usually happens when you have jammed paper) or use a blower to clean any foreign objects.
Apr 27, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Mar 01, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Printer malfunction
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 03, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Sep 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannon MP810 when turn on display error A600. There is also no light displaying on the printing cartridge.
A600 or 6A00. If 6A00 then the fault code is for the AP motor position error. Error lies with the sheet feed unit, Purge unit or Logic board.
http://www.tradebit.com/filedetail.php/4588588-canon-pixma-mp810-printer-service-manual
This is a complete service manual
Sep 14, 2008 | Canon PIXMA MP960 All-In-One InkJet...
Error 6A00 and my printer not printing
AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ass'y (QM2-1548)*1 Don't know it means but the service manual says the above
Mar 21, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
239 people viewed this question
old marine
old marine
