Question about Durabrand Televison & Video
TV not working
When I tried to turn the tv on a load pop came from the back of the tv it will not do anything now ( only 8 months old)
  • 86 Answers
You have destroyed a power capacitor or IC from your main circuit board, if there is no power then it may be the transformer too. It will need replacing - the repair in total is artound 50$ or more so save up. Most TV's come with a 1 year warranty if new. do NOT open or fiddle anymore to avoid voiding of this, mr TINKER
Posted on Aug 16, 2008
SOURCE:
New 60ph6700 hd 3d tv /watchind hd sports fuzzy grass and background/once in awhile lines run through screen/its only two wks old??
Anything new has a chance of failure the first month or so from cold solder joints on circuit boards. If it passes the first month it may last 8 or 12 years. Send it back under warranty.
Nov 29, 2013 | LG 60" 6700 Series Plasma HDTV - 60PH6700
My Vizio TV (less than 1 year old) has green/red vertical lines on the left side when first turned on. They go away in 10-20 minutes.
Hello. If your POP (Proof of Purchase like store receipt) is less than 1 year old you have to contact Vizio immideately and setup appointment for authorized technician in-home service.
You might have problem with LCD Panel (or plasma whatever you have) that result of manufacturing defect and reveals itself only after several months of use. You still covered by manufacturer's warranty and you don't need to pay anything to get your TV fixed or replaced.
After warranty expiration replacing a panel generally cost more than buying new TV.
Act as soon as you can and don't try to fix anything by yourself.
Regards.
Russ.
Dec 01, 2010 | Televison & Video
Popping noise from speakers
You have a problem indeed. try lowering the tv volume . if the signal is too high on tv it can cause some problem with the sound system if that dosent work then you may have some electronic sound output resistor problem.
Aug 15, 2009 | Teac DC-D6300 CD Shelf System
Won't turn on
one of the inverter transformers has gone bad replace the bad one and the set will work fine ,there are 6 transformers in the 32".
Oct 02, 2008 | Emerson EWL3706 37 in. LCD Television
Blown Picture
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
Aug 18, 2008 | Samsung FP-T5884 58 in. Plasma Television
Tv cuts itself off after about 2-3 minutes
try unplugging it to reset it 7 call the manufacturer. is it under warranty, do you have a dct?
Apr 21, 2008 | Televison & Video
TV Shuts off by iself!
Don't feel bad about Mits. All the projection companies and all the new TVs have markedly poorer reliability than the good old CRT types. You should see all the class action lawsuits against even some of the best companies!
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 13, 2008 | Mitsubishi WS-65711 65" Rear Projection...
TV wont turn on and blank screen & no sound
this unit is dead ,possoble power supply problem. you must have warranty on this unit if its only 8 months old,if not contact place of purchase and ask wath is the life expectancy of their products and your tv set it start them thinking about repairing or replacing.
Aug 22, 2007 | RCA F27650 27" TV
After 20 months old and now dead
I purchased this tv 2/06 and it went POP in 04/07. Less than 60 days after my warranty expired. Went back and forth with Zenith for several months. I refused to take NO for an answer. Customer service stinks and you have to be very persistent. They eventually agreed to fix it. Repairs cost over $2000 and I have my tv back. Next time it breaks just going to throw it out. Zenith sucks.
May 09, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
37 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
