E9 error message - Washing Machines
    Brigadier General:
  • 6,277 Answers
You have not told us the make and model of your washer and different makes, models have different fault codes so I am therefore having to totally guess!!!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has at least assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 28, 2011
Testimonial: "Thankyou! The guidance notes are great!!"
Bloomberg freezer error code e9
Error Code E9 ' Appliance Video
www.appliancevideo.com/repair-help/question/error-code-e9
The unit keeps getting a low water error and everything I could think of checks out: inlet valves, w. ... Error Code E9 ' Appliance Video .... Ice on bottom of freezer
Jul 23, 2015 | Blomberg BRFB1150 | 11.7 cu. ft....
Fix for Janome error E9
take it to a repair shop the computer control is faulty
Apr 19, 2015 | Janome Sewing Machines
Our AW-1170S Toshiba washing machine ia showing error code E9-5 error message . How can I fix it.
Pam: This code relates to WATER PRESSURE , could be a (1) Krink hose, (2) plugged strainer where water enters the machine ( doing it's job) or (3) a sensor that malfunctioning (thinking you have NO water pressure. These sensor prevent the machine from operating dry, flooded etc, some times they OVER protects. So check the first 3 items above. you may have IN HOME service on it.
Feb 09, 2015 | Washing Machines
How do I get rid of error message E9
e9 I believe is no clerk signed on with a Sharp register. If you have a sharp register just press 1 then "sign in" If not a sharp please repost with the model #
Oct 13, 2014 | Retail Supplies
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
E9 ERROR IN HITACHI AC
HI
MY HITACHI WAC MODEL for 1.5 lr, DISPLAY SHOWING E9 ERROR CODE. ALREADY COMPLAIND TO HITACHI CUSTOMER CARE, BUT NOT GETTING POSITIVE RESPONSE. NOW CAN YOU PLESAE LET ME KNOW WHAT DOES THAT (E9) ERROR MEANS AND HOW TO RESOLVE THE SAME?.
THANKS
Jul 04, 2012 | Heating & Cooling
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
Error message E9
gebje,
error codes on pentax camera's are in the repair manual to help the technician find the problem faster. e9 is shutter failure and will need to be repaired.
May 10, 2008 | Pentax IQZoom EZY-R 35mm Point and Shoot...
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
