Question about Brother MFC 6490CW InkJet Printer
Brother mfc-6490cw lcd screen shows no display (just the backlight is on)
    New Friend:
I installed a new router, and my screen went blank. Seemed it was lost. I removed the printer from my computer. Then I downloaded updated drivers. And reinstalled the software, and it was back again.
Posted on Nov 29, 2017
Lcd blank not carakter
Posted on Jun 30, 2011
  • 1,116 Answers
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 02, 2011
The LCD display screen is blank, back-light remains on. Powering off machine to power back on results in loud, abrasive rattle which seems to come from scanner. Unable to do anything with device.
When this happens the first thing you should do is check the connections to the LCD screen. However if it was working fine before this is most likely not necessary since they have to be connected properly to show anything. After that you would need to replace the LCD or the Logic board. If everything else is working properly then the problem is more than likely the LCD needs to be replaced.
Mar 12, 2014 | Brother MFC 6490CW InkJet Printer
Unable to clean 46 in brother mfc 6490cw printer machine
  • Press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
  • Enter maintenance mode 80, by pressing the up/down arrow key and set key to select numbers 8 and 0
  • Press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
  • Use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter.
    Press Stop/Exit key to go to root of maintenance mode.
  • Enter 9,9 to exit maintenance mode
Jul 06, 2011 | Brother MFC 6490CW InkJet Printer
I have purchased a MFC 6490CW printer in Germany. can I change the language in LCD screen from german to english on MFC - 6490CW?
Yes under settings there will be a language option, just have to go through the process in the German Language
May 22, 2011 | Brother MFC 6490CW InkJet Printer
I have recently installed a Brother MFC-6490CW printer on an iMac with OS X 10.6.6. When attempting to print, I have a choice of two printers: 1) Brother MFC-6490CW (default) or 2) just MFC-6490CW. When...
You have 2 printers because it was inadvertently installed twice. You need to un-install both of them and reinstall the printer again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2011 | Brother MFC 6490CW InkJet Printer
Is Brother MFC-6490CW printer can print double sided?
No, that model does not print Double Sided (Duplex). You can see all the features and specifications here: http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
Mar 10, 2011 | Brother MFC 6490CW InkJet Printer
Cannot get a wireless signal show on Brother
Try to change the Channel in your router , try changing it to Channel 10 , normally that works to sync with printers.
Mar 13, 2010 | Brother MFC-640CW All-In-One InkJet...
Brother MCF-6490CW will not intall drivers with Windows 7 Ultimat
The drivers should come inboxed with windows 7 on the official final versions. Later on the drivers also will be released on brother's homepage(s), but they usually take some time before uploading drivers to the homepage when new OS' are released. Try using the Add Printer Wizard and see if you're able to find the MFC-6490CW in the list of printers available.
Apr 16, 2009 | Brother MFC 6490CW InkJet Printer
Brother MFC 6490CW InkJet Printer Logo
1,051 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
