Question about Neoware Systems c50 Thin Client Network Terminal
Printing to a local device connected to a thin client through terminal services
I use a thin client to access a remote desktop and can not seem to get the printer that I have locally connected to work. Any ideas?
Chad Hanner
My view,in RDP Protocol the printer should be pcl base (network printer)in which printer having Ethernet port.The network printer connected through switch or in local client, in that way you can give print from any client to particular printer.
In host base printer it can't be print or install through client because of locally it has no storage device so the storage device is in server.The printer software is in server.That so network printer can be install in remote desktop protocol(RDP) or in wireless.
chiranjib das
Posted on Jul 18, 2012
Posted on Nov 19, 2009
Are you attempting windows printing? DOS printing? Model of Printer?
Posted on Oct 08, 2008
We have a DHCP problem with our thin client HP T5540, the network interface can't get an ip address fom the DHCP server for 30 seconds so it can't connect to citrix xen serverver for virtualization...
First of all check the configuration of the unit if it's AUTOMATIC IP/DHCP, if all OK you can test by configuring a static IP (use an unused IP in the server's DHCP table) than check the connectivity (ping something), if that works you have a server rule/DHCP or DNS problem
if it's still not working check the cabeling and connectors for connectivity (with a good cable tester) or an other (working) computer.
Oct 22, 2010 | HP t5540 VIA Eden 1GHz Thin Client...
Hi. I want to set up a server and run dumb terminals (thin clients) off of it. Can anyone give me a basic run-down about how I do that?
You would setup Windows Server. Windows Server 2003 and 2008 Small Business Server comes with a license of Terminal Services Server.
You would first need to setup your Windows Server. Install it according to at least minimum requirements.
Make sure you assign this server the correct role. If this is the primary server and if you intend on hosting dns and dhcp on this machine, then please make sure you are assigning this server these roles.
You will need to create user accounts so that you can log into from your thin clients.
Next you need to run the install for Terminal Server.
Next you need to configure each thin client.
Next try to access each thin client via Remote Desktop as well as the server.
This is the basic run down of the process. If you do not know how to setup a server then you will need to ask that question as this is very detailed. Also you will need to be more detailed in your question as to whether this is a linux based network or a windows based network.
Hope this helps. Please don't forget to give me a good rating as well as your vote.
Apr 02, 2010 | Network Computing Devices (NSH800S/A)...
Setting up Terminal Services on Server 2003 at the head office of a client in a workgroup environment, no Domain Controller. The branch office wants to log in through a VPN Router ( Linksys RV042 that has...
Assuming you can connect via Remote Desktop without any issues...
Printing through Terminal services requires that printing be enabled in the Terminal Services Configuration (Client Settings Tab). It also requires that the printer driver be installed on the Terminal server, not the actual printer (as it shows under the control panel) but just the driver. You can install just the driver by going to File/Server Properties under Printers and Faxes ON THE TERMINAL. Install the printer normally on the client machines.
Note: For a printer to work via Terminal services it needs to have a compatible driver (which I believe is called PCL??) So some consumer printers (the ones that only come with Setup programs, not just driver packages) will not work. The majority of HP Officejets and laserjets are fine, as are Brother lasers.
Oct 27, 2009 | Microsoft Windows Server 2008 Terminal...
SIte to site vpn/remote desktop
Open up the vpn client any any of the working machine, and then
click on
file>>save Prfoile>>give a name
Take a copy of that and paste it in your machine.
On your machine install the vpn client (Straight Forward Installation). Then
Click on Import Profile , Identify the location where you have pasted the profile (Which is copied from other machine).
You are done with that.
Mar 13, 2009 | Cisco PIX 501 Firewall
Access remote system devices
if need to access the device of your client,just follow the steps.
we take cd rom for eg to access.
1.right click the drive there you see "sharing and security"
2.click on the and enable share as cd rom.and give maximum allowed.
3.then from your system.Run->ip of the machine->enter.
4.it shows all the share file of the client machine
if want access remote desktop
1.enable the remote desktop connection in the remote machine
2.in RUN type MSTSC the remote desktop connection will popup.
3the type the ip of the client machine
Mar 20, 2008 | Computers & Internet
Printing throw terminal server
Are you remoting into your server from a differnet location than where the server is? I need to know th physical location of the printer to the server. If the printer is connected to the server there is a problem with the driver. if the printer is connected to your local PC you will need to click on the options button in remote access and tell it you want to use local resorceses. If the server / Printer / PC are in the same location do not access the server thru terminal services, set it up as a client server.
Dec 25, 2007 | D-Link Express EtherNetwork DP-301P+ Print...
Compaq T20 printing
dear you will have to make a print server then you can share you printer,install the printer driver then access from client computer then you can use both printers
Sep 17, 2007 | Compaq Evo T20 - 128mb Flash (305253001)...
Toshiba PA1390U-1NKP fails under Windows Terminal Services from XP to Svr 2003 R2
I don?t have the equipment to test your setup; however, I suspect your problem is in redirecting the device to the terminal server session. Check the terminal server system event log file to see if you are generating any messages when you connect. When my users have issues, typically with printers, they will be listed in the log as *Errors* and the source will be *TermServDevices*. If you?re using the latest Remote Desktop Client there is a tab in options called Local Resources which is used to deal with configuring your workstation sounds, keyboard, printer, and other local resources to redirect to the terminal server. Click on the More button at the bottom and you will be taken to the more generic section of resource redirection that deals with other items. Your device is probably USB so if it is going to work is would fall under the scope of the section labeled *Supported Plug and Play devices*. You would start by placing a check in that box, reconnect and see if you keypad works now or if anything shows up in the event log. Let us know how this turns out and if you have any other questions. As always please don?t forget to rate this post.
Apr 03, 2007 | Toshiba PA1390U1NKP Keypad
Open Questions:
Neoware Systems c50 Thin Client Network Terminal Logo
517 people viewed this question
Top Neoware Computers & Internet Experts
David Payne
David Payne
Are you a Neoware Computer and Internet Expert? Answer questions, earn points and help others
