The service light is on, machine only 13 months old
    Brigadier General:
  • 6,277 Answers
You have not told us the make and model of your washer so I am having to guess!!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
Methinks you could do with a manual!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 28, 2011
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
My 3 month old bosch 300 series washer isn't draining completely and errors at the start of the rinse cycle with E13 falshing along with the rinse light. Help!
the E-13 error code is a drain timeout code. This means the pump has run a certian amount of time without fully draining itself. This could be anything from a clogged drainline in your home to a clogged drainline in the machine, your pump is clogged, pump is burned up, no power to the pump, bad board etc. Most of the time its either something jammed in the pump, or its burned up (from something being jammed in it). Just have to take her apart to find out for sure.
Aug 10, 2008 | Bosch Washing Machines
Keurig B60 can't get the power to come on.
Mine just did the same thing, 13 months old :( Talked to customer service, but tech advisor was not available. They said someone would call me back within 48 hours....Figures I just bought 2 others, one for work
Sep 09, 2010 | Keurig B60 Coffee Maker
My Washing Machine 13 month old, was repared 1
Likely the ECU is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
13 month old kenmore 48112/48116
lights are flashing and beeping while not running any cycle.. Please help.
Dec 20, 2008 | Washing Machines
7 year old dishwasher motor needs replacement
No one is going to do anything for you at 7 yrs old- maybe 13 months, but not 7 yrs.
Nov 27, 2008 | Dishwashers
Water valve P/N 8577407 failed after 13 months
If you ever buy anything from Sears, always keep a warranty,we do and had to use it alot.
Jun 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Mdl WTW6600SW
some times well a lot of times if you call cust assistance and your that close to your warranty they will comp the call but if you didn't send in your warranty card and haven't had a service call then they don't know when you bought it be sure to get cust assistance and not cust service f 50 is the code for a stalled motor see if your basket spins freely
Sep 16, 2007 | Whirlpool WTW6600SW Top Load
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
