My excavator has hammer piping , what do i have to do to get my tilt bucket to work in both directions. regards joe
  • joe_tippexc May 29, 2011
    its a 5.5 tonne aus digger with IHI pumps and piping. The hammer works perfectly i just need to know what fittings to use and where to use to use tilt bucket.
    Thanks.
  • 1,141 Answers
5j 5 j5yu j56uj 56j
Posted on May 29, 2011
  • 1,555 Answers
Kindly let me know about the equipments make and model number so that i can provide assistance.
Posted on May 28, 2011
How do I tilt the cab back to get access to the pipes under my JCB 2007 8014
Yes it tilts to about 20 degrees.
At the front on the cab / canopy is two large mouting bolts. You undo these but first you need to sort out the aux pedals and the dirt cover that goes over them.
I think thats some hex bolts. Once that is off you can unclip the pedals and then undo the main bolts and the cab will hinge backwards.
Its a one man job until you need to put it back down as you need to relocate the slew lock.
You may have to unclip the tracking levers in the middle of all of that but there only on small clips so its easy to do.
The hinge locks in place so you will have to unclip it for it to return back down.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
8014 8016 Conventional Tail Swing Mini Excavator DirectIndustry
Mar 01, 2015 | Jcb Bruder JCB Loader Backhoe
Excavators boom
Is the machine leaking any fluid?
Jun 19, 2013 | BIT EA10F Earthquake Earth Auger Bit 10"...
Lifted up the dehumidifier onto a counter to empty the bucket and removed/clean the filter. Completed this task, replaced the filter and bucket, then sat the dehumidifier and it tilted a bit backward but...
It does have a tilt over safety feature. But if it wasn't plugged in when it tilted, it shouldn't have tripped the switch. However, if it was plugged in, it probably tripped the switch. Check your Owners Manual for how to reset the switch.
Feb 06, 2011 | Haier DE45EAL Dehumidifier
Aprilaire 550 clunks on shut off. Never did this before. Changed the saddle valve and Solenoid. Checked copper water line for possible vibration on a pipe, nothing. I'm stumped
Thank you for contacting us regarding the "clunk" sound you are experiencing with your Aprilaire 550. The noise you have described is called water hammer. Water hammer is a pressure surge or wave resulting when a fluid in motion is forced to stop or change direction suddenly. Water hammer occurs when the solenoid valve closes at the end of a humidification call. To prevent the sound of water hammer, we recommend contacting your heating & cooling contractor to install a "shock arrestor" part number 4280. This device is installed between the water pipe and the solenoid valve and will absorb the shock and stop the banging. Please contact your heating & cooling contractor or our Customer Service Department if you have further questions. Kind Regards, Jessica Garrett Customer Service Specialist Research Products Corporation
ww.aprilaire.com
Oct 30, 2010 | Aprilaire Humidifiers
We moved the dryer and tilted it to adjust the feet to make it level. now it puts out very little heat. doesn't matter what heat setting it is on - the same small amount of heat. any suggestions?
It sounds like you have crimped the vent pipe and partially blocked the flow. Pull the dryer out from the wall, unhook the vent pipe and check to be sure you don't have a partial blockage of lint or maybe a kink in the pipe. Regards, Joe
Jan 13, 2010 | Whirlpool LGR7646E Dryer
Boom creeping down on case c28 excavator
your spool valve needs rebuilt
Nov 01, 2009 | Garden
Excavator track needs to be put back on
after the idler is pushed all the way back into the frame.try to put some wood blocks under the track to remove all the slack.use the bucket to push as much of the bottom section under the bottom rollers.use a heavy chain and pull up and over the top of the roller.when you get close you can use the drive to walk it the rest of the way.if it still doesnt go you may have to break the track at the master pin. this is usually marked with a small hole drilled in the end of the pin.heat and beat the pin out,break the track.pull track over top rollers and make ends meet on top of the srocket.use a chainfall to pull two halfs together and line them up.drive pin back in and your all set.
Mar 01, 2009 | Gladiator Gear Track Pack
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
