Question about Braun Contour 5885 Electric Shaver
Braun series 5 5874 when i push to start will not start it is charging and has power. can you help
4 Suggested Answers
SOURCE: Braun Series 7 760cc dead after 2 months
Had this same problem with mine. One month after warranty was done with. I ended up opening the thing up and pulled the monster battery out of its socket and put it back in. Worked fine after that. One week and still strong. Another thing I did was to carefully bend up the flat pieces of copper around the battery to make sure they were still getting a good contact with the pins on the cover. Hope this works for you....
  1. The black rubber/plastic cover on the back will pop off if carefully pried apart from the gray plastic. Start around the middle of the razor body.
  2. Once the black piece is removed you will see four screws holding on a plastic cover. These can be removed with a sharp flat head screwdriver.
  3. The plastic cover can then be pried from the razor body. Be very careful though as there is a rubber seal around this to keep water out. I broke mine.
  4. Inside you will see a somewhat large red battery with prongs on either end. Pop it out of its location and wait a couple of seconds. Press it back into position and you should hear a click for both ends.
  5. After this, I took all of the flat copper pieces and gently bent them towards myself (without making them touch of course... this could cause a short and potentially cause the battery to explode).
  6. Replace everything and see how it works... Hopes this fixed it for you and saved you $100-200. Have a good day!
Also... I am not responsible for any damages that may occur.
Posted on Feb 02, 2010
I had the same problem with my Braun Pulsonic and managed by luck to fix it without having to take it apart. All I did was to leave it out of the charger for a couple of days. The blue light was on constantly which drained the power. Once the light had gone off I recharged the shaver and all was fixed!
Posted on Jul 31, 2010
vetteman3002
  • 2299 Answers
SOURCE: Braun Series 5 8975 The shaver
Did it just instantly quit? Or does it act like the battery is just really low?
Posted on Sep 16, 2010
Reset light has appeared.What action is required ?
There is no Reset Light as far as I know and the manual seems to indicate the same. I have a series 5. The green light shines when you are using it. The red light flashes when the power in the battery is less than 20%. Put it on to charge and the light will flash green until it is fully charged and then the light will be solid green.
All of the manuals are here from Braun
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=subgrp&sgrp=subgrp&grp=SH01%3C%7C%3ESH02%3C%7C%3ESH03%3C%7C%3ESH04%3C%7C%3ESH08%3C%7C%3E&s=&subgrp=Series+7%2C+9000+series+-+Pulsonic%2FProsonic%2CActive+P
This manual page is showing the light indicators.
http://www.manualslib.com/manual/20437/Braun-Series-7-720.html?page=8#manual
Braun SERIES 7 720 User Manual Page 8
Apr 01, 2016 | Braun Series 7 720 Electric Rechargeable...
Braun series 3 no longer holds a charge. what can I do?
It is not that young anymore. The rechargeable battery is (almost?) dead. It is almost impossible to replace it. I once tried it, took me more than a day yo put everything together and still it never was as before.
I have bought a new Braun (799) and I'm convinced this one will live longer. The rechargeable battery in this one, you can shave one hour before you need to recharge it. It lasts a week with me, or sometimes even longer, before I have to charge it again.
Perhaps you just use the shaver with the power cord, like we used to do for 20 years, and start saving for a new one?
Oct 14, 2014 | Braun Series 3 Electric Razor Shaver 370cc...
How to fix a Braun series 7 razor that will not charge in cleaning stand
Try plugging the cord directly into the shaver. If it charges this way, your clean and charge unit is bad. A replacement can be ordered from the link below
http://shaveroutlet.com/braun-pulsonic-clean-charge-base.html
May 27, 2014 | Braun 7000 Series Foil and Cutterblock
Can't get the 7526 cleaning arm to stay down on the shaver for charging, cleaning, etc. Is there a sequence e.g. hold the arm down then select a cycle, or select then push down? What is the blue button...
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing your existing clean and charge machine is not an option, you will find the entire machine available at the link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
May 08, 2011 | Braun Syncro 7526 Electric Shaver
When I charge my Braun it does not charge.But sometimes it charge. I do not know what to do
i have series 3 wet and dry braun shaver when it ison charge it only sends ared light to show on grip never it blue charge what is possibly wrong
Feb 23, 2011 | Braun 4775 Smart Control3 Razor Series 3...
My Braun 7526 will no longer clip into the razor for cleaning and charging.
If the arm on the charging stand no longer locks down into place to charge the shaver, you will need to replace the arm or you can replace the entire charging unit. You will find both items at shaveroutlet.com. See links below<br /> <br /> arm only<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html</a><br /> <br /> <br /> complete base<br /> <a href="http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html">http://shaveroutlet.com/braun-7000-series-syncro-clean-charge-base-p-122.html</a>
Aug 27, 2010 | Braun Syncro 7526 Electric Shaver
Shaver Stopped. May need power unit series 569 class 2 for series 1 150
By 'power unit', it appears that you are referring to the power/charging cord. If this is the item you require, you will find this item for model 150 (series 1) at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun-charger-cord-for-select-models.html
Mar 19, 2010 | Braun Health & Beauty
Braun Contour 5885 Electric Shaver Logo
91 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
