Question about Toshiba 42HP95 Television
720 and 1080 resolution
Cannot get a picture at 720 and 1080 resolution. TV is connected to Directv HD-DVR with HDMI cable. Plug another TV into the HD-DVR and it will play at 720 and 1080, therefore must be setting on the 42HP995?? Help!
  • 5 more comments
  • Capkirk Aug 16, 2008
    Per owners Manual "This input (HDMI) on your TV is designed to accept HDCP program material in digital form from EIA/CEA-861/861B-compliant consumer electronic devices (such as a set-up box or DVD player with HDMI or DVI output). The HDMI input is designed for best performance with 720p signals but will also accept and display 1080i, 480i, and 480p signals."
    The above statement is why I thought my TV would support the higher resolutions.
  • Capkirk Aug 22, 2008
    Have not heard anything yet on a solution!
    See section from owner's manual above.
    From Specification list: 720p True HD Display
  • Capkirk Aug 23, 2008
    TV supports 720p. Anyone have any other ideas??
  • Capkirk Aug 24, 2008
    I don't think its the DVR as I plugged the HDMI cable into another TV and got both 720 and 1080. Also DVR is not Toshiba, but whoever makes them for Directv. Its a simple connection, HDMI from DVR to television. TV is capable of 720, but doesn't work. At a loss.
    Not DVR as I plugged another TV into the DVR via HDMI and got 720 and 1080. Also DVR is not a Toshiba but whoever makes them for Directv. It's a simple connection, HDMI from DVR to TV, and TV supports 720, but for some reason can't get 720, only a blank screen with audio.
    Master:
  • 763 Answers
Try to see the settings from your hdtv. it must have a settings on that one. ill find another info about this and ill try to ask somebody about this!
CHARCOIS
Posted on Aug 24, 2008
  • 157 Answers
The TV's firmware should be upgradable but can only be done by the authorised service centre. Can be done for free if its still under warranty. Call to book for a home visit from a tech by calling the authorised service centre. They can upgrade both ur TV and DVR
Another possibility is that ur HDMI cable that ur using is loosing the digital signal. This is a result of poor conduction through the cable as a result of wear and tear of the cable itself. I would recommend using a gold plated cable because they transmit the digital signal without any loss
Hope this helps
Cheers
Jigsaw
Fixya Team
Posted on Aug 23, 2008
    Genius:
  • 1,269 Answers
A firmware update needs to be done on your HD DVR
How to check firmware of your DVR? Check the link below
http://tacp.toshiba.com/tacpassets-images/notices/hddvd-checkingfirmware.asp
You can download the FW on the manufacturer's website
Posted on Aug 16, 2008
  • Toshiba Master
  • 19,396 Answers
Check that 720 and 1080is within allowed resolutions, check the manual.
  • Ginko
    Ginko Aug 23, 2008
    Ensure the HD-DVR is set to 720 by 1080 in output.
    Sergeant:
    Champion:
  • 417 Answers
Depend if your TV dos 720 & 1080 ill look into this more for ill get back 2 u soon
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
I have bose v30, dishnetwork 612 dvr. When
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues.
What is happening is that when video resolution changes (like from regular programming to commercials) the video information is poorly sent down the HDMI line. Component cabling from your DVR will eliminate this problem.
I hope that helps.
Feb 06, 2010 | Bose 36037 Remote Control
I have a Panasonic Viera TV, a Panasonic DVR, a Sony home theater system and a HD cable box --- how does all of this connect (to get the best picture)?
Hopefully the tv has multiple HDMI inputs.....
Plug HD cable box straight into tv with HDMI
All other inputs into home theatre
HDMI from home theatre to tv HDMI
Aug 03, 2009 | Panasonic Audio Players & Recorders
How to adjust from 480p to higher resolution up to 1080
several things use hdmi cabling, also change resolution (can sometimes be changed on front of direct tv receiver) or may have to go through menu to change to the different resolutions. also turn the native mode OFF! having the native mode on for directv will give sometimes give you odd pictures. also whatever resolution you choose through directv menu's make sure your tv is also set to the same resolution
Apr 04, 2009 | Televison & Video
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Dec 29, 2007 | Televison & Video
Televison & Video Logo
339 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
