Question about Samsung Televison & Video
Samsung UE32C5800 LED TV purchased 6 months ago. Has suddenly developed a flashing picture. Sound is not affected, or anything else, but picture 'strobes' quite severely. Can hear a flicking type noise coming from the actual TV itself as well. Have unplugged, checked cabling, settings etc....Is it faulty?!
jerryg50
  • 1689 Answers
SOURCE: panasonic 50 inch plasma
You should call for warranty service. If the set is very new try to get it exchanged.
There are some very heavy duty power supplies and many high power matrix drivers used in Plasma sets.
The description sounds like the noises are very loud. It is normal with any of these TV sets, if you put your ear right up to the back of the set at the vent holes you will hear some noises. These would be some acoustic harmonics from the power supplies and related circuits.
I am wondering if it is possible that there is something that is becoming less stable. If the set is working very well without any failure, so-far this is a very good sign. Before it gets to be a problem, I would have this checked.
On many models of these sets, they use fans for cooling specific areas. A bad fan can cause noise.
Jerry G.
Posted on Apr 14, 2008
SOURCE: lg 42 inch tv, power but no picture and a high pitched sound.
My picture is making people look like cartoon characters, ral red like. then it may play for awhile normal
Posted on Oct 08, 2008
freetek
  • 5568 Answers
SOURCE: ESA Plasma PDP4294LV No video,sound
 checked voltages meter set to AC referenced to chassis VA, VE, etc no voltages.
Do not try to measure voltages on the primary side of the power supply with a meter; you may damage the meter and cause new damage to the supply. There are switching frequencies somewhere between 50,000 - 100,000 Hz and possible voltage peaks of several hundred volts.
Checking AC is only useful before a diode bridge that converts incoming AC into raw DC that is then chopped at higher frequency into an approximate HF AC, coupled to the secondary, then tapped and connected to more diodes to produce DC, finally regulated and sent on its way.
Your plasma set uses some higher voltages that could have caused the cracking sound they heard but the DVD player didn't cause the problem directly; maybe just caused the HV for the display to surge for a moment.
You may have additional fuses on the secondary side of the supply. If test points are accessible there, check for DC voltages and be suspicious of any fuse or test point that measures nothing at all.
I can't tell you which voltages to expect since that varies from one design to another but you should find several lower voltages such as 5 VDC for logic circuits and perhaps a 12 V point. The plasma's HV could be produced from a separate board fed from the AC line or get its supply voltage from the main supply. There aren't many standards to rely on here.
The most likely semiconductor failure would be on the secondary side and diodes come in many different packages, many cylindrical, some in the TO-220 package with a metal flange and mounted on upright aluminum heatsinks. These will have only two leads and there will be some in the same package with three legs. The latter can also be checked statically but unless you know what kind of transistor or regulator (look about the same) you are measuring, you will not be able to ferret out a defective one with any luck.
While you have the set open, check for any dust bunnies that can act as sponges, collect moisture and create a discharge path for higher voltages.
Posted on Dec 27, 2008
jscruggs420
  • 36 Answers
SOURCE: Humming from back of tv
sounds like your powerboard, you can try a cheap fix by putting a small fan behind the tv on low and see if that helps. Also I would not settle for this and call in the warranty and get it fixed while you can.
Posted on Jan 18, 2009
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
Samsung LED TV problems
try first with the led strips noo need replacing t-con
Feb 27, 2017 | Samsung UN40ES6100 - 40" 6 Series...
Samsung LED TV, sound but no picture
Have you tried unplugging it and letting it reboot?
Nov 12, 2016 | Samsung Televison & Video
Samsung 50" led un50h6350. The TV is about 18 months old and the picture went out, the audio and back light are working. I've replaced the t-con board and that didn't fix it. Someone please help!
Samsung LED TV Screed goes blank periodically for 1 sec - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - Lately, my Samsung LED TV's screen will black out from 1 -2 seconds then come back. The TV has been ... The TV is about 6 months old. .... I've only notice this when I'm watching in HD. ... by Stlouib / January 13, 2012 11:18 PM PST ...Mine does the same thing - picture goes black for 1 - 2 seconds and then comes back. Samsung Series 3 (330), won't show any picture/no sound?
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
More results from www.cnet.com
Are there still capacitor problems with Samsung TVs?
Dec 21, 2015 | Samsung Televison & Video
I have a Sony Bravia, Model: KDL40BX450. It's red 'stand-by' light has suddenly gone off and I cannot turn on the TV. What's going on?
I have a sony Bravia 40" LED TV. KDL40BX450.When I turn my set on it has no sound. And the standby light blinks three times and pauses. I have unplugged it. and even reset it to the factory settings. And as long as the set is on the sound works.but once I turn it off. and turn it back on later.it does the same thing again.no sound. what could be wrong .And is there anything I can do to maybe fix it.
Dec 12, 2012 | Sony BRAVIA KDL40BX450 40 Inch 1080p LCD...
My samsung dlp has no picture or sound. Model hls5066wx, power comes on lamp light flashes for 15sec and then the standby lamp comes on then it goes back to the lamp light flashing. It repeats this a few...
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 12, 2009 | Samsung HL-67A510 67" DLP HDTV
PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
Jun 15, 2009 | Samsung PN50A450 50 in. Plasma HDTV
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
