Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
TRYING TO REMOVE COLLAR THAT CUTTING PLATE IS ATTACHED TO THANKS AS I AM CHANGING CHASSIS AND IT HAS A LARGER PLATE THE MOWER IS A 5HP BRIGGS AND STRATTON
  • 79 Answers
SOURCE: 190cc 3in1 briggs and stratton mower wont start...
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
Posted on Apr 25, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
canbruce75
  • 1776 Answers
SOURCE: I have a troy bilt mower with a briggs &
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
  • 3600 Answers
SOURCE: what type of oil for a 650 series briggs and
Use 30 Wt. motor oil, I prefer castrol but it is up to you, Mobil is also good and Texaco or Union 76, if you use it in different times of the year say in the winter you may want to go to a mid range of oil say 10/30 depending on the conditions you use it in at extreme cold and extreme hot temperatures you want a oil that makes it easy to start and still protects the engine with a good film of oil. If you have any more questions about this post here with a response.
Posted on Aug 29, 2009
  • 143 Answers
SOURCE: Briggs & Stratton Modle# 100000 will not stay started.
your engine is only running on the fuel you are pumping in, the carb. is not lifting the fuel on its own, maybe because of water in the bowl or dirty jets. You must take the bowl of and clean it out and depending on the type of carb. it might need a new diaphragm. Stephen.
Posted on Apr 25, 2010
Testimonial: "very helpful. will follow instructions. Thank you"
Where can i get briggs 5hp valves with over size stems
try an engine reconditioning shop
there are a number of ways to go about it
a mower shop may be able to help find a place that sells valves
a recon shop may be able to supply valves with larger stems and then remachine the stems to take the spring retainer and collet
if it an overhead engine , it is easier to fit new valve guides and standard valves
if it is side valve engine , it maybe cheaper to get a new crankcase
it will be a case of making a lot of inquiries from engine people, mower repair shops and even searching the net for valve manufacturers and seeing what valves they have that suit
Nov 30, 2016 | Garden
Where is the plug to change the oil?
Amy, if drain is not in the bottom of engine by blade, turn mower on it's side to drain oil to change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change your Briggs Stratton engine oil
Toro 6 5hp GTS Oil Change mpg
Mar 26, 2016 | Poulan Pro Pr550n22sh 22-Inch 140cc Briggs...
Dirt in fuel, how to remove gas tank
Not sure how helpful this really is, but these are the drawings and parts lists for your engine.
http://www.partstree.com/parts/?lc=briggs_and_stratton&mn=135292-1180-E1
Jun 17, 2014 | Briggs & Stratton Briggs Stratton...
How do we remove deck from 2007 yardman mower?
Craftsman aka sears....has a parts lookup section on there website. Enter your model number and have a look.
May 18, 2014 | Briggs & Stratton Garden
Bolens 42 in riding mower with briggs and stratton
Check the battery and battery lead terminals are clean (wire brush or a scotchbrite) and tight.
Still not working: - then check the battery lead connections to earth (chassis), starter solenoid and starter motor.
Feb 05, 2014 | Briggs & Stratton Garden
5hp Briggs & Stratton, idles great, but won't throttle up.
Hello, I have a older B.S. replacement engine for my sears riding mower. I have got it all installed but my gas tank is in the rear under the seat. The engine doesnt come with a fuel pump. I bought a vacum pump but does'nt have a port. I under stand the in and out on the pump. I took the engine cover off looking for a vacum port and cannot find one. I also looked all around the intake not one there. The only thing is the air breather. Can someone assit me in hooking this up to make it work. Thanks so much
Aug 27, 2009 | Boating
Lawnboy F series Engine - how to remove PLATE AND COLLAR ASM
shaft is tapered plate just slides up on shaft, tap with hammer several times if want break loose,sometimes moisture has rusted it or excess heat has swelled it on tight, i had to take a drimel tool will cutting disk to remove mine,then clean up shaft with file or sandpaper to smooth,little grease an new collar ready for blade.
Apr 12, 2009 | Garden
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
46 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
