HI, I am looking for the parts manual for my Kohler Marine Generator Model: 40EF0ZD The engine is John Deere Model: 4045TFM75 Sr.: PE4045T627575 Would appreciate your earliest response as we need to carry out the overhaul Rgds Nigel
arealplumber
  • 33 Answers
SOURCE: Schematic
I looked for several minutes and this is what I found:
Kohler 13EOZD wiring diagram
I went to the Kohler site, entered the number and it cross referenced to the above number. The wiring diagram is on page 90.
Hope this helps!
Posted on Dec 05, 2008
SOURCE: JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Posted on Mar 21, 2009
  • 153 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
What is the oil filter part number for Generator engine serial number CD4045C037188?
your number 4045tf258 should be a industrial generator that number is the model number
John Deere 85 KVA 4045TF258 for sale Price 7 359 Year 2005 Used John Deere... notify john deere and use the model and serial number [i have 2 different numbers and are as follows RE506178 Oil Filter 1 RE5 9754;the first should be the new number and the other was the old ] just to make sure of the correct parts number for your unit
Aug 19, 2016 | John Deere 225 325 375 500 650 Alternator...
John deere 110 kohler engine k 181 s
very interesting photos of a generator of the engine
what is the problem with it as you forgot to make any statements as to a problem or how to fix.
Jul 06, 2015 | John Deere Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
Kohler marine generator troubleshooting
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
May 02, 2012 | Electrical Supplies
1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
May 26, 2010 | Kohler Electrical Supplies
John Deere Mower Engine Issue
HAVE YOU CHECKED THE CARB AT ALL? LOOK AT THE LINKAGE & MAKE SURE IT MOVES FREELY! IF CARB CHECKS OUT MAKE SURE GOVENER IS ADJUSTED RIGHT!!
Sep 05, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Need to order engine parts for a c314h john deere riding mower
If there is no #'s you can call John Deere or go on there web site and should find some info.If you have the model of the tractor john deere can tell you what engine you have. If you have an engine # they can also help you.Good luck. donnyb60.
Mar 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Electrical wiring for kohler engine
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
