Can i have a e-copy of a manual for thomson washing machine tx9612-A/01?
4 Suggested Answers
SOURCE: how to use thomson washing machine tx 708
solved.
Posted on Jan 28, 2010
I misplaced the manual of my Thomson TX829, please can you advise where I can obtain a new copy.
Posted on Dec 05, 2010
  • 6277 Answers
SOURCE: WAA28160GB / 01 FD 8510
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 19, 2011
Thomson fs21811ce-A
Greeting....anyone has a copy...I need a copy ofThomson FS21811CE-A instruction manual? Thank you.
Thomson
FS21811CE-A Dect Phone Manual
Dec 20, 2011 | Alcatel Lands Phones
How to use thomson washing machine tx 708
Jan 15, 2010 | Thomson Washing Machines
Thomson TX238 drain hose leaking.
Disconnect from power supply , remove screws , remove panel.
Nov 09, 2009 | Washing Machines
The drum of my tThomson Washing Machine is stuck as the frame has
hi..
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
You will need to call Fisher Paykel so they may direct you to a local technician. the water valve assembly will need to be replaced at this point.
Aug 24, 2009 | Thomson Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
