Question about Nokia N900 Smartphone
When i switch ON my fone it starts and within a few seconds turns OFF. battery is completely charged but it does not start. shuts down in 5 seconds.
  • affan_rowdy May 28, 2011
    when i connect it with my PC but it does not start so i am unsable to scan it.
  • 77 Answers
Hi..
I think its a virus problem.
you have to scan your mobile in PC with desktop antivirus and Net Nrotector is best for the mobile scanning.
Posted on May 28, 2011
  • HyperTeHK Jun 25, 2011
    Have you tried to remove the battery, reinsert the battery and start the phone with the netadapter, DO NOT plug it in usb will powering on because that can also create a problem like you discribe (at least with my n900.)
    It is most definatly not a virus, since there are no Linux ARM virusses and you are not booting far enough for a virus to do anything.
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
My powercom UPS model no. is IND601A.It shuts down on its own with beep going off.the device doesn't function at the first attempt but it takes 4-5 attempts to get started.I mean to say when press start...
Please open and check your battery. possible that it has gone weak. Put the set on and do not switch off as the batttery needs the trickle charge to keep fit.
This is do-it -yourself site and we do not recommend any company.'But check for a search for Powercom Power supplies.. Might help.
Sep 02, 2010 | Powercom Computers & Internet
Nokia 95 8GB is dead
man check it with a new battery or it may b posible that ur fone s/w is crrupet which need to reinstall by a expert .
Dec 25, 2009 | Cell Phones
Compaq nx5000 with new battery and new power
Dear,
Try pressing the CAPS LOCK. If CAPS LOCK is responding then it is surely your inverter.
It is a known problem with the nx5000 series laptop.
The FAN switches off because Intel SpeedStep which is absolutely normal.
I faced and solved at least 6 - 7 such problems on different nx5000 laptops
If CAPS LOCK is not responding then its your motherboard.
Good Luck and Regards
Nov 25, 2009 | HP Compaq nx5000 Notebook
Power shuts dowd
the battery is not charging correctly or has a fault contact nintendo
Aug 06, 2009 | Nintendo DS Lite Console
Laptop won't start
remove battery and check if is charged.
put back battery and connect power supply.
keep ON button pressed few seconds until it flashes.
if not started wait few second and try switching on normally.
if unsuccessfully check both power supply and battery with manufacturer
Jan 11, 2009 | Computers & Internet
Switch on!!!!
PLUG IN CHARGER AND SEE IF IT STARTS TO CHARGE IF IT DUSE NOT GET NEW CHARGER IF IT DUSE START TO CHARGE TRY TO TURN ON AS IT IS CHAGRIN IT SHOULD COM ON MAKE SHORE THAT THE BATTERY IS HOLDING A CHARGE
Jan 10, 2009 | Nokia 3110 Cellular Phone
SONY DSC-H9 WON'T STAY POWERED UP
I think that both your batteries are bad. Because the batteries have sat on a shelf not being used the batteries will only take a surface charge and not fully charge. Bum a battery from someone with a Sony that uses the same battery and see if that works.
Sep 20, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Nokia N900  Smartphone Logo
61 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
