Can't open the CD driver disk
I mjust bought a 2x SPeed USB floppy disk drive, but my computer cannot open the Driver CD that came with it.
    Genius:
  • 1,011 Answers
Dear,
install the driver through other souce like cd or download it throuhg net it will not heavy ...
regards,
dont forget to rate it dear
Posted on Aug 16, 2008
SOURCE:
How to get sony 2x fdd external mpf88e/ua/181 to work on windows 8?
Try to use the windows 8 generic floppy drive driver. Legacy hardware is difficult to make work. You might want to see if you can download and install multiple drivers for similar floppy drives and see if one of them works.
Jun 18, 2014 | Sony 2X Floppy Disk Dives External...
I have a Teac USB portable diskette drive, N533. Until recently, it has worked okay. However, it has started not opening any diskette I put in and instead a message appears that the disk needs to be...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 28, 2011 | Teac IBM USB Portable Diskette Floppy...
I have a SmartDisk External USB 3.5" 1.44MB Floppy
well you I&hash39; have got problems the first thing i would be looking for would be a bad driver to this device if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
if the problem still persists check the leads that attach to this device make sure they have secure seatings or just replace them they could be faulty from overstreching
hope this helps
Apr 14, 2011 | SmartDisk USB Floppy Drive Titanium...
I need to remove some photos from an old computer. Windows 98;. Is not able to be connected to wireless internet. I bought a Cruzer Blade USB Flash Drive 4 gb. Will not work. As I cannot download a...
If the Windows 98 computer does not have a USB port and you cannot copy the photos onto a floppy disk or burn the photos to a CD then the only option is the following.
Remove the hard disk and connect it to a USB hard drive adapter and then plug this into a USB port of a working computer. This computer will see this as an external storage device, you can then open the various folders and copy your photos to this computer or to a USB flash drive.
Oct 07, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I reformatted my Vista computer now need the driver
You can find the drivers off your computer retailer such as Dell or HP. If it isn't a retail computer, you can find it off the manufacturer's website such as ASUS.
Mar 07, 2010 | Sony 2X Floppy Disk Dives External...
We want to install win Xp in Toshiba Satallite A205-S5825
Depending on the model of your Toshiba, it may have an unsupported hard disk controller which requires that you load a disk driver from a floppy disk by pressing F6 when prompted during the boot of an XP installation CD. If so, you will need to download the apropriate driver and put it on floppy diskette, Of course a floppy drive will also have to be available during the boot. (enable USB legacy support in BIOS if you use a USB floppy drive)
Alternatively, check your BIOS settings to see if the disk controller can be set to operate in ATA mode rather than AHCI mode. ATA mode should work with the XP cd-rom.
Dec 06, 2008 | Toshiba PA1381U-1ETC Consumer Headphones
Samsung USB floppy disk drive won't work without the CD-ROM device driver...
Here http://www.fixya.com/support/r6260295-samsung_sfd_321u_drivers
You will find SAMSUNG SFD 321U DRIVERS For windows above.
Jun 29, 2008 | Computers & Internet
Bought a usb floppy drive reader to convert my floppies to my laptop. have plugged in the usb cord. what do I do now?
Its easy to use:
Step 1). Just on your lap.
After complete boot
Step2). Insert your floppy connector one end to your USB port of Lap.
Step 3). Double Click on My Computer Icon.
The my Computer will be open.
and if every thing is ok, a floppy disk drive icon [A: or B:] will be shown in the window.
Step 4). Insert your floppy disk into the Drive.
wait till the floppy disk drive light goes off.
Step 5). Double click on floppy disk drive icon [A: or B:].
and the content of the floppy will be open.
have any question... ask me
Thanks
Iqbal
Mar 22, 2008 | Computers & Internet
Can not get new plug and play usb floppy drive to recognize floppy disks.
Did it work before?
If yes, then it died.
If no, then replace it.
Mar 16, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
41 people viewed this question
Ekse
Alun Cox
