Question about Sewing Machines
I need help in getting the top and bottom loopers correct on a Singer ultralock14U34.a\ A munual would help!
    Brigadier General:
  • 7,191 Answers
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Posted on May 28, 2011
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
I A NEED PARTS NUMBER FOR SINGER OVERLOCKER 14U134A LOWER LOOPER
See if you can call Singer customer service to get a parts list. They might even look it up for you and help you get it.
Sep 13, 2014 | Sewing Machines
Singer 756u stitches not catching
So this is a serger? Might have been nice to know that. Make sure you have threaded your serger in the correct order. upper looper, lower looper, needles from right to left.
Make sure you do this with the presser foot lever in the UP position. Make sure all the threads are pulled fully into any tension guides.
Sep 01, 2012 | Singer Sewing Machines
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
My 14sh654 singer Serger tension must be off and although i have watched the video and read the manual repeatedly I can not get the lower looper to tighten. My stitching is very loose on every tension...
possible causes. not threaded correctly, actual probelm with tension, burr on neelde plate presser foot or looper. check to see if after you thread that particular tension if there is any resistance on the thread after it passs thru tension, if not see if thread or lint is in tension disc. clean out it present then try again.
Sep 25, 2009 | Singer 14SH654
Just replaced my uppper looper on my white 1634....
Hi.
The upper looper goes just in front of the needles. I had issues with my machine when I got some fabric jammed and the looper moved so it wasn't catching the left needle and it was sewing a straight stitch on the left. The looper needs to be placed in front of the needles and very close to the needles without hitting them.
Hope this helps!
Cherie
Nov 01, 2008 | Singer White Speedylock 1634
Mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
www.bargainbox.com.au
Apr 26, 2008 | Singer 14SH654
Upper and Lower Looper Rub Together!!
Your loopers need adjusting, impossible to explain how to do this, you need to be shown. Can I suggest you contact a sewing machine tech, sure it will cost but if he is a decent guy he will show you how to adjust the machine.
Apr 23, 2008 | Singer 14SH654
Sewing Machines Logo
14 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
