My cable dont work no more my power went out i accidently pushed buttons and now my cable dnt come on my tv no more
    Sergeant:
    Novelist:
  • 159 Answers
This is a pretty common problem ... sometimes when the power goes out, the cable box at your house will reset some settings that the cable company had set. I know it is a pain to wait on hold for someone to help you, but most likely you will have to call the cable company's customer service line to talk to a representative there. They will be able to walk you through getting everything turned back on -- and they will also be able to tell you if there is a hardware problem on your end, or if it is a connection issue from their end.
I wish I could be more help on this, but I have had to deal with it several times in the past, and if resetting the box (unplugging it for 5 minutes, then plugging it back in) does not work, they probably have to reset their end as well.
Posted on May 28, 2011
Accidently pushed a button and then the tv went fuzzy so i pushed standby but nothing worked, then i pressed power and it keeps clicking on and off and wont stay on
Check power supply board located on the Right bottom board,in the middle is a 6amp Fuse it could be blowed.
Located on the Left Hand side should be the Big Black ICs will have part number on them STK392-110 ,Bad STK ICs can cause this also.
Mats Electronic Parts 1-800-628-1118 they will have ICs ,ect...
Jul 20, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
The remote accidently has S video button pushed. I have S Video at the top of a blck TV screen. I'm not sure how to get back to the TV screen because no button is working. I run the TV through the...
Use your TV remote to change the input away from S Video. There should be an Input button or Video Source button. Press this button repeatedly to cycle through the inputs. Depending on how your cable box is hooked up to your tv, your input will vary.
Jul 18, 2011 | Vivitek Televison & Video
How to switch off psm in bpl tv?
first you can take og remote controll,then press and hold power key.this time tv will going off.bt dont relealese power botton of remot...after turn on tv...........tv will psm off.......
dkm kerala
+919447259335
Jun 01, 2009 | Televison & Video
TV Will Not Turn Off With Digital Cable Control
The remotes you get from the cable company are universal and kinda cheap. ive ran across this multiple times but since i dont know what model remote you have the only advice i can give is that the code you used is not the right code if it doesnt do all basic functions (on,off for the tv,volume)its just the wrong code if the codes you stated are the only ones available the book you got with the remote should explain how to run an auto scan.hope i was some help
Feb 01, 2009 | Symphonic ST419E TV
No signal
you have to take the remote, find the input button, push the input button untill your picture comes back, you should see the input go from cable/antenna, to vid 1--vid2---vid3---if pushing the button a couple of times dont change it, you will have to hit the input button, then arrow down, and select the nexy one, do that untill you find the picture
Jan 10, 2009 | Sony KDF-E42A10 42 in. LCD Television
RCA M134C 27V412T
hi there, you can try the front panel switch to unlock it or to turn it on. if still same problem you do have an electronic parts trouble with your unit. check the power supply section of your tv and test some electronic parts. ty
Dec 24, 2007 | JVC AV-27D302 27" TV
Tv just wont turn on
power supply fault it could be any component if not qualified dont risk taking a look inside, high voltage supply.
Oct 14, 2007 | Panasonic (LSSQ0372) Remote Control
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
Philips TV set PC7225-PC121
JUST GO THE MENU AND PRESS INSTALLATION. SELECT AUTOPROGRAM. AUTOMATICALLY SYSTEM GOES TO DEFAULT MODE.
Aug 04, 2007 | Philips 25PS40S 25" TV
No picture or sound
take you tv to tech you have damaged your microchip and component in the power supply
Dec 20, 2006 | Samsung TXN3245FP 32" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
