Question about Craftsman Garden
Installation craftsman lawn tractor bagger model 917.249791
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Posted on Sep 22, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
How to install a Husqvarna leaf bagger
The bagger installs by using the supplied bracket on the rear of the tractor. Mount the frame of the bagger onto the bracket. then connect the discharge tubes using the spring connecters. Flip open the lid and slide the bags into the frame.
Sep 04, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Sears riding mower will not start after it killed.
first thing you need to do is check and make sure the blades are disengaged set the park brake and try to start it again all newer mowers will not start without parking brake set or depressed and blades or pto in the off position good luck
Oct 07, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need help on installing a 2 bin hard bagger on a craftsman lt1000
call sears, and ask them to get you the manual.
Nov 20, 2011 | Garden
Have a Craftsman LT1000 and the discharge pipe on the grass collection tube continually gets clogged. The grass is not wet or overly thick and the blades are sharp. Engine RPS's good and i always cut...
Inspect the inside surface of the discharge tube. If you do not find any hangups, then I would wonder how fast you are mowing. If you are going full speed, I would recommend that you slow just a little. I was just thinking, have you been doing the same thing for a long time and recently have this problem develop. So, give good inspection. I do not know what type of bagger you have, but is the air able to escape the bagger, if it is not then it sets you up for a clog. If you can not find anything on detailed inspection of bagger system, there are sprays for under the deck of lawnmowers to minimize the chance of grass clinging to the underside of decks, you could try applying that to the ducting of your bagger. I hope this is helpful.
Aug 22, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Our craftsman garden tractor model no. 27603 doesnt fit a bagger!
ALL craftsman side-discharge tractors can accommodate a collector. If you can't get one specifically for your model, a universal one will fit.
It takes the form of a couple of plastic bins fitted to a frame that is mounted on the towing eye on the back of the tractor. A large diameter tube runs from an adapter 'boot' that fits over the discharge opening, to the bins on the back.
I'm in the UK, but we sell loads of these kits. SInce they come from the States, it shouldn't be a problem.
May 07, 2010 | Garden
INSTALLING CLUTCH CABLE ON CRAFTSMAN
the proper threading of cable clutch for 38 in. craftsman riding lawnmower model 271150
Mar 29, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
How do I install the grass collector
Assuming that you have the correct grass catcher..... Install the discharge deflector at the deck discharge. This is the smaller piece that bends 90 degrees. It will slide into clips on the deck when you have the deck's plastic deflector raised up. Next, install the bagging assembly. It's pretty straightforward. Lastly, install the plastic chute (tube). Push it in the grass catcher (bagger) opening, and then pivot it over the deflector and down onto it to seat it. Connect the straps.
Best regards, --W/D--
Aug 10, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
367 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
