No sounds coming from my computer - Computers & Internet
  • 336 Answers
Try to check-up control panel then system>hardware>device manager>sound,video and game controller.maybe not yet install already sound drive.
if same problem again.try also to BIOS setup restart PC press F2 or DEL to go BIOS>advance you can there your sound card (enable or disable)choose enable.then press F10 to save.booting again.
if same problem no sound your onboard or PCI sound card defective IC chip replace it.
Posted on May 28, 2011
    Sergeant:
  • 207 Answers
Check the volume level on the system tray on on the control panel if the volume is muted. One indication when you can't adjust the lever of your volume is that your sound card doesn't have the driver installed on it. Check your motherboard manufacturer if it is a onboard device the go directly to its website and support link. You'll find drivers there for your audio device and simply download it and run into your PC. Hope it helps. Thanks for any vote.
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Makes sounds.
Where does the sound seem to be coming from?
If the sound is coming from the rear (rear fan), it might be the power supply.
If the sound is coming from the inside of the computer, the problem might be another fan on the inside (such as the CPU fan). If that is the case, then usually the computer will turn on for a short time and then cut off. When this happens, the computer when on, overheats and then shuts off.
Hope this helps! Let me know if it does and please vote. Thanks!
Dec 01, 2013 | Dell OptiPlex Computers & Internet
I recently installed a new modem provided by verizon then lost all of my sounds. Can you please help me recover them ?
You're saying that there's no sound coming on your computer or you lost the songs save on your computer?? If the problem is there's no sound coming from your computer make sure the sound device is working properly check it under device manager..
Hope that helps........
Aug 19, 2008 | Computers & Internet
I have a 32" LG
Hello Undernet01,
Yes, it's very simple. Connect the computer speakers to the headphone socket on the TV, then run a separate audio cable from the PC to the TV. A PC monitor cable wont carry an audio signal so you need to connect an RCA type cable or similar - depending on whether you have corresponding audio OUT sockets on the PC and audio IN sockets on the TV.
You will then have sound from both the PS3, the PC, and the TV on the computer speakers. The TV speakers will automatically switch off when something is plugged into the headphone socket.
Simples as pies.
BElectric
Dec 26, 2010 | Computers & Internet
Why do I need a sound card for my laptop pc?
Hi. Sound card is a device inside your computer that is responsible for the sound coming out to your computer. Without the sound card there will be no sound comes out to the laptop.
Oct 09, 2010 | Computers & Internet
Sound coming from only one speaker
> try to check the settings from the sound properties
Jun 14, 2010 | Insignia 2.0 Speaker System (2-Piece)
Sound not working properly!!!
Run microsoft update and make sure to select all updates (even optional). You will see hardware updates (if there is any) and this may fix the issue. Let me know if not.
Good Luck!
JL
Dec 30, 2009 | Audio Players & Recorders
Sound wont come out speakers
Not to sound like I am taking the pi**, but arae you sure you plugged into earphone/audio out????
Try using a pair of earphones you know work and if you get sound then the speakers could be faulty.
Nov 06, 2009 | Juster Computer Speakers
Sound divice
sound is not coming in computer due to that their is no sound driver install in computer...just install sound driver from your motherboard cd and sound will come
gud luck
Jun 13, 2009 | ASUS P5VD2-MX SE Motherboard
Sound not coming out of the rear or center speakers
Sort of confused a bit I understand you buying a new system you say the sound does not come out the rear and centre speakers does the sound come out of any spearkers other than the two you mention if it is then your wirings are wrong if the sound is not coming out of any speakers then its the sound card BUT you will know this immediately you disconnect that system. The sound would be coming out of the laptop ordinaryly? which is it?
Sep 04, 2007 | Logitech X-530 Computer Speakers
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
