Question about Acer Aspire T310 PC Desktop
Hi when i on my desktop it will run for few second and it auto shut off and my monitor the light will keep on blinking (blank screen).model acer T310
  • 126 Answers
Well buddy for that you have to perform following steps:
read this article
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
when you come to advanced boot option screen, select Last Known Good Configuration.
if the problem still persist, then again enter into Advanced boot option and select
Disable automatic restart on system failure if still the problem appears then please let me know
Posted on May 28, 2011
Acer Aspire not going into POST
If it wont POST-then prbly hardware problem-inspect MOBO -disconnect all drives and try to boot into BIOS
Jan 30, 2010 | Acer Aspire T310 PC Desktop
Acer Aspire PC T310 boot up problem
try bios reset, all common problems occur after a major power outage or power spikes... try resetting the bios and it should work fine, if not try replacing the video card and start from there...
Jan 02, 2010 | Acer Aspire T310 PC Desktop
My Acer LCD Monitor AL1707A goes blank after 2 seconds
Try this,
When laptop on booting immediately press del.
And the screen will run normally.
But if the screen is still white, force to press power button soon.
And it will shutting down.
After shutting down, repeat this action.
It will work.
Vincent-Jember
Nov 05, 2009 | Acer Computers & Internet
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Acer 4520 Power up for 1 second and turns off
Can you hear the system fan running? If the fan fails, the PC shuts down itself to protect the processor from FRYING.
Apr 14, 2009 | Acer Aspire 4520-5582 Notebook
Acer t310 fan runs when shutdown
More than likely the cpu is still hot even after you shut off you computer, so as a saftey precaution the fan is trying to cool it down,(which is a good thing).
Jan 06, 2009 | Acer Aspire™ T180 PC Desktop
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
Acer Aspire T310 PC Desktop Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
