Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Colored plastic sheet in light tower has fallen to bottom of tube
I cannot figure out how to remove the clear tower tube in order to reattach the plastic color in the tower tube so the tube changes colors. It's the Wurlitzer 1015 vinyl model.
  • BobDavisFL Aug 16, 2008
    They don't just slide out. the light bulb is inside of the tube as well as the wiring on top and bottom.
    Wurlitzer 1015 Juke Box. The light towers have a plastic sheet of color inside of them which revolve and give a barbershop light effect. The colored sheet has detached from the tube and fallen to the bottom of the tube. How do I remove the tube in order to reattach the platic colored sheet?
I need to purchase new plastic sleeves that rotate to change the colors in my wurlitzer 1015 cd jukebox. Where can I buy them?
Posted on May 26, 2009
    Genius:
  • 1,011 Answers
Dear,
check this link...and try..
http://www.flippers.com/wurlitzr.html#parts
regards,
Posted on Aug 16, 2008
    Sergeant:
    Champion:
  • 230 Answers
You better check this link ,it will help you
http://www.grandamericajukebox.com/page2.html
    Brigadier General:
  • 3,614 Answers
  • 19,396 Answers
You can also find some information here :
Jukebox restoration
    Sergeant:
    Champion:
  • 417 Answers
I Think They Should Just Side Out
wow its been like 3 years since i did this i think
that's how i did it tho
Why dose p e come up and how bo i fix it please
"PE" error is related to the Harmonic pressure switch. Since the
part is electronic, I would suspect a clog at the air dome at the
bottom of the tub located at the rear of the machine. The pressure
switch is located at the top. Unplug the washer from power, you will need a small piece of 1/4" plastic tubing or copper tubing. Locate
the pressure switch, disconnect the 1/4" tube from PS. Attach the
PS hose to your plastic or copper extension tube. Try and blow thu.
You should hear bubbling of air. Draw alittle water in by sucking and
blowing several times. This should clear any thing lodged in the lower
air dome. Before you reattach the hose to pressure switch, first trim
1/4 '" of hose off, for a tight fit. But before attaching hose, plug in washer and Press POWER, Press SPIN SPEED, Press START
to activate pump to remove all the water left in the tub. Next lower the
Pump's Trap Door at the bottom left corner of the cabinet. Using a kitchen trash bag, Extend the black rubber hose into trash bag and remove the plug. Turn off the machine when all water has been
evacuated.. Unplug washer and reattach the hose to the pressure
switch and try again.. IF error returns replace Pressure Switch..
Aug 15, 2014 | LG Washing Machines
I have a Samsung SR-21NME. It is leaking into fridge from the evaporation vent in the freezer. Any idea what I can do to fix it?
Unplug the fridge. Remove all the food, and all the shelves or racks from the freezer, and figure out how to get the rear sheet metal out (screws) To access the evap. area. Using a hair drier or 2 letter drink bottle full of very warm water. Defrost the coil and make sure you clear the drain at the bottom. Flush the drain as good as you can. Check for any loose or broken wires, look for a switch that should be clipped on to the tubing, if it has fallen of its clip try to re-clip it on to the tubing. Be very careful of the coil it has very sharp edges and will cause a nasty cut. You will make a mess, get plenty of towels, and or a shop vac. Once all is clear put it back together. Hope this Fixya up.
Dec 04, 2010 | Samsung Refrigerators
There is minimal suction in the hose. Nothing appears to be blocking the hose.
You most likely have a gasket out of place.
1. On the bottom, there is a panel held in by two screws. Open that up. Inside you will see a white gasket that should be aligned with the hole. If it is not aligned, you will not get good suction.
2. The other gasket will you require you to take out the two screws on the blue cover (at the base of the unit where the dial is). You will see a black plastic tube with two clear tubes attached. Remove the two tubes. remove the screw holding the black plastic tube in. Inside is a red gasket. Ensure that is in the correct place. Reattach screw + clear tubing. Reattach blue cover.
Let me know if this helps.
Feb 01, 2010 | Bissell 9200 Upright Vacuum
MY WHER25 REV. OS. IS LEAKING AT THE HOLE IN THE BOTTOM OF THE SPOUT . i CHANGED THE FILTERS.. IT STILL LEAKED.. I CHECKED THE DRAIN GOING INTO THE P-TRAP .. IT WAS CLEAR .. PLEASE HELP
Remove the faucet spout and unscrew the screw keeping the white plastic piece on the bottom (of the faucet). It's where the red and black tubes enter. Pull out the white plastic with the tubes and clear it of debris (usually placed there when your disposal backs up the black tube, which serves as the filter's drain tube). Once it is cleared of debris, make sure the black rubber washer is back in place (it may be stuck in the faucet, so look for it) and replace the plastic, screw the screw back in, and secure the faucet again. I had this same problem and doing this solved it. Should take about 5 minutes or so. Good luck.
Dec 02, 2009 | Whirlpool Home
Water leak from ice maker
The fill line internal to the freezer is likely frozen up from the elbow inward.. When the icemaker calls for fill...pressure builds up on the plastic tubing causing it to pop out of the elbow. Check the tube inside the freezer by removing icemaker and running a long thin screwdriver or a rigid wire up into the tube until you feel ice or the plastic elbow outside.
Clear ice, if present, by squeezing hot water in from freezer side with turkey baster until cleared and water comes out back.
Aug 21, 2009 | Amana Refrigerators
I have a 3m thermofax 45cg every paper run through is completely
I am a major seller of these machines in ebay. The machine may need a new potentiometer. Build a carrier. Put two pieces of transparency plastic sheets together with a piece of tape and use this to carry your stencils. This will reduce the heat of the lamp. Rouben (rouben@ektalc.com).
Mar 23, 2009 | Office Equipment & Supplies
Kenmore toaster oven handle fell off
try magic putty. it works on everything
Jul 11, 2008 | Toaster Ovens
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Brother MFC 6800 shows Replace Drum Soon even after replacing drum
Put back the sheet in.
Remove the drum, put back the starter sheet in with the flat edge toward you.
Turn the drum left gear to get the sheet in till the plastic notch are even with the edge of the sheet.
The put back the drum in the printer unit, close the unit and printer will eject again the sheet clearing the message.
you may have to try this more then once, the sheet should be at the right place in order for the message to clearout.
You also need to clean the 1/2 inch plastic windows at the bottom of the printer prior to put back the Drum. this will allow the laser to get to the drum unit more accuratelly.
Don't use alcool, or any liquid. this could damage or scratch the clear plastic windows and thus alter the print quality.
Feb 21, 2008 | Brother MFC 6800 All-In-One Laser Printer
How to remove freezer door
push colored rings toward white collar while pulling hose from coupling
Jan 31, 2008 | Whirlpool ED2SHAXM Side by Side...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
433 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
