Question about Lenovo 3000 N200 0769 Intel Celeron 530 1.73GHz / 512MB DDR2 / 80GB HDD / DVD Player/ CD Burner / N... PC Desktop
Sir i want to check our lenovo 3000 that it contains correct RAM,HDD and everything in it. and another problem is that i have os win 7 proffesional so that i am not able to install c language in it.
  • 1,179 Answers
Yes it looks like it, to run the C language you will need to dual boot Windows 7 and Windows XP. Or install only WIndows XP. Another idea is to install a Virtual Windows XP Operating system. Therefore XP running in a Window of Windows 7. Called virtualization.
However virtualization is not possible on this model of Intel CPU.
Take care!
damnor01
Posted on May 28, 2011
From where i can download win8 drivers for lenovo 3000 Y410
If you have upgraded the Laptop from Windows Vista to Win 8 , Did you do a Hardware compatibility test? You may be in for bit of a mess. Take a look at this: http://howto.cnet.com/8301-11310_39-57390888-285/check-your-hardware-for-windows-8-compatibility/ The driver's are another issue, sometimes you can use Win 7 drivers, change compatibility, and modify the drivers to work with your hardware. I have done it , and it can be quite a pain, and quite frankly not worth it. I would suppest Win 7. When you "jump" two OS's ,Vista to Win 8, it doubles your fun.
Jan 16, 2013 | Lenovo 3000 Y410 Laptop
Lenovo ThinkPad T520i Battery
Have you check your Charger for Proper Voltage? Is it Providing Proper Voltage to your Laptop? Check it First.
This Problem can Happen due to bad Charger or due to the Charging IC not Functional properly, which is located on the Board of the Laptop
Aug 11, 2012 | Lenovo 423947U - Thinkpad T520I 423947U...
Lenovo 3000 n100 webcam revert image
what do you mean revert? you mean inverted? you probably don't have the correct webcam drivers installed. go here: http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/63cn09ww.exe
Feb 05, 2012 | Lenovo 3000 N100 Notebook
Sir, In my lenovo y410 laptop i installed windows 7 after that i tried to burn win vista dvd.After giving options all the content on the dvd is safely copied then dvd rw opened after putting empty disc my...
First of all, try to put other empty disc(or other disc, which contains data) in your dvd rw. See if it detects your CD. If it detects that means the problem is with your empty disc. If the computer an't detect your disc, go to Control Panel and see if any device has yellow mark. Make sure that drivers for your devices of your computer are installed correctly. If some device has yellow mark, that means you need to install drivers for this device.
If the problem continues, go to http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
for additional information.
Apr 06, 2011 | Lenovo 3000 Y410 Laptop
When i install audio driver of lenovo g450 then its shows a error your media device cannot found
try to install the audio driver of G530, this is the link:
for win vista OS
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_show_215.html
for win 7 OS
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_show_1943.html
remove your current audio driver by device manager:
click start > run > type devmgmt.msc
under audio, right click the device and remove the driver
then restart pc and install the driver
Apr 18, 2010 | Lenovo 3000 G530 Notebook
I want os for Lenovo 3000 Y410 series
I use always XP SP2, Vista & Win 7 are brain dead for older hardware, drivers etc, XP SP2 always works, maybe SP3, sometimes.
Feb 28, 2010 | Lenovo 3000 Y410 Laptop
Open Questions:
lenovo 3000 N200 2048k ram passed Hay I am siva I am using the Lenovo 3000 N200( core-2) model laptop that system operation is vista but I am change to win- 7 professional 2 days have same hard drive corruption problem there showing all way this message A problem has been detected and windows his been shut down to prevent damage to your computer , If this is the first time you’ve seen this stop error screen, restart your computer .if this screen appears again, follow these steps Check for viruses on your computer .remove any newly installed hard drives or hard drive controllers, check your hard drive to make sure it is properly configured and terminated .run CHKDSK/F to check for hard drive corruption and then restart your computer . Technical information : Stop :0x0000007B (0x80D86B50,0XC000034,0X00000000, 0X00000000,) I am try to all when I restart the system there come windows error recovery launch startup repair ( recommended) then automatically go to the startup repair setup few mint check the repair then restart again go to the same setup start windows normally I try select the normally mode not go to the logon page again come same page how to solve the problem pl tell me I am try to all fun key nothing happened Phoemix TrustedCore(tm) NB Copyright 1985-2004 Pheonix Technologies Ltd. HDL10 BIOS Version 61ET33WW (V2.02) CPU = 1 Processors Detected, Cores per Processor = 2 Intel(R) Core(TM)2 CPU T5500 @ 1.66GHz 1024M System RAM Passes 2048K Cache SRAM Passed System BIOS shadowed Video BIOS shadowed Press [F1] for SETUP, Press [F12] for boot device selection menu Pressing F1 changes the bottom line to "Entering SETUP...", but nothing else happens. Nothing happens if I press F12.
Jun 01, 2012 | Lenovo 3000 N200 0769 Intel Celeron 530...
Lenovo 3000 N200 0769 Intel Celeron 530 1.73GHz / 512MB DDR2 / 80GB HDD / DVD Player/ CD Burner / N... PC Desktop Logo
94 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
