Question about Dell (6F858) Cooling Fan
My Dell Inspiron 15R fan is not working....the laptop gets overheated due to this & shuts down after 15-20 minutes.The laptop has exceeded its warranty period.I had bought the laptop in May 2010.
  • Dell Master
  • 32,281 Answers
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Posted on May 28, 2011
  • 1,179 Answers
You either need to get a laptop computer technician to replace the fan, or you need to find a replacement fan and install it your-self.
Choose which ever option best suits you.
Take care!
damnor01
Notebook 3521 is shutting down after some minutes for unknown reasons. Any suggestion about the problema?
Common problems are faulty battery, or overheating due to faulty fan. If the machine shuts down when on mains power, listen carefully for the fan. If the fan is silent or slow , you could try using a vacuum cleaner to clear any fluff out of the fan unit or get hold of a laptop cooler tray. If the unit doesn't shut down on mains power, you should get the battery checked.
Mar 02, 2015 | Dell Inspiron 15 Notebook Inspiron 3521
How do i get the keyboard to light up on my dell inspiron 15r with windows 8.1?
Can you give us the model number of the computer? it would greatly help narrow down the solutions!
Thanks,
Dennis Aspinwall
May 29, 2014 | Dell Inspiron 15R Laptop Computer (Intel...
How do you get on bios on a dell inspiron 15r laptop
Shut down the laptop completly, & while starting it again , as soon as you are gonna press the power button, start hitting the DEL butoon multiple times untill you see bios page............
Mar 27, 2014 | Computers & Internet
Overheating dell laptop
Laptops tend to overheat when air flow is not good. To prevent it from overheating make sure you have the fans cleaned, there are plenty of tutorials out there on how to do it, or just go to your local shop and ask them to do it. if all else fails you may need to acquire a fan base, they are pretty cheap and can make a huge difference!
Mar 25, 2014 | Intel Dell Inspiron 15r N5010 Laptop...
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
Dell inspiron n 4010 hangs often
I suggest you open the laptop, and clean it out first. THEN go on with the diagnoses.
Dell Support > Inspiron n4010 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/insN4010/en/sm/index.htm
1) FIRST remove all power. Remove the AC adapter (Charger) and Battery.
2) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components on a computer.
Relieve your body of Static.
You should use an ESD wrist strap, and connect it's alligator clip to a good ground source.
This is an example of an ESD wrist strap,
http://www.radioshack.com/product/index.jsp?productId=2103245
This pictorial guide for disassembly of an Inspiron n5010, should help also.
http://www.insidemylaptop.com/taking-apart-dell-inspiron-n5010-inspiron-15r-laptop/comment-page-1/#comments
The screws, and cables, etc., are in a different place, but disassembly is still the same.
Use a can, or two, of compressed air for computers.
Also you may wish to use Q-tips, and a soft small brush.
(Makeup brush? )
DO NOT use a vacuum!!!!
A vacuum creates Static electricity.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 15, 2012 | Dell Inspiron 14 Laptop Computer (Intel...
After about 10 minutes,everything completely shuts down . I expect a heat sync problem? what do you think?
I think you're right. Sounds as if the system is overheating. Check the fan is working. If it is, you will probably need to open the case and clean out all the vents & the fan. Remove the heatsink, clean off old thermal paste and renew before replacing the heatsink
Mar 14, 2012 | Dell Inspiron 1525 Notebook
Inspiron 6000 shuts down while playing Magic Match. I have it sitting on external fan, so it's not overheating. This is the only game so far, that shuts it down after 15 minutes of play.
This could be down to a graphics driver that needs updating or a direct x problem. Try updating the graphics driver and see if that resolves your problem.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
Overheats and shuts down after about 20 minutes
Usually when a CPU overheats it shuts down and after it cools down you can re-boot it again.
Continual overheating will eventually cause the CPU to fail.
The overheating is usually caused by blocked vents and or dust build up on the heatsink and/or fan. Remove this dust from the heatsink and fan and this should fix your overheating problem, unless you have a faulty fan, in this case you will need to replace the fan.
Feb 18, 2009 | Dell Inspiron 2650 Notebook
Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Jul 22, 2008 | Computers & Internet
Dell (6F858) Cooling Fan Logo
677 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
