Question about Music
Randall RM100LB user manual I purchased a new
Randall RM100LB user manual I purchased a new RM100LB and new moduals all boxed withouth ant instuctions manuals I need user manual
  • Music Master
  • 11,800 Answers
You will need to contact them directly at - amp.support@usmusiccorp.com - and ask them to mail you a new manual .
Posted on May 28, 2011
Where can I get an instruction manual for a Casio Tone Bank CT-6115
There is no such model.
If you are referring to CT-615, you can purchase a PDF copy of manual from ebay
http://www.ebay.com.au/itm/Casio-CT615-Keyboard-Users-Owners-Manual-CTK-615-/200932122034
Nov 02, 2013 | Music
Manual pdf
Here is a useful link that will answer most questions about this case.
I think the Randall should be Series-Parallel wired for 8 ohms
Speaker Wiring Diagrams
Oct 27, 2013 | Randall RX412 4x12 Cabinet
Interference
check the receptacle its plugged into sounds like it may have a loose neutral.
Feb 11, 2013 | Randall KH15 Kirk Hammet Combo Amplifier
I have a RH50 T amplifier, it had a bit of a bumpy car ride to band practise the other day and now when i play through it, it will make a permanent buzzing noise on the clean channel that gets 70% worse on...
You may have damaged the variable resistors (the volume controls), you can purchase replacements from a local Electronics store (if UK based try Tandy). Otherwise have you checked the speaker itself for damage? You may have split the speaker which will need to be replaced.
May 04, 2011 | Randall RH50T Tube Series 50-Watt Guitar...
What is the part number for the footswitch for the RX120RH?
Hi i believe the part number is RAN012
Hope this helps
Kind Regards
KnowHowRebel
Mar 06, 2011 | Randall RX120RH and RX412 Half Stack...
I recently purchased a yamaha PSR-E223 YPT-220 keyboard from Argos.when we got it home and opened it there was no adaptor.We are unable to find the one we need.The manual states we need a PA-3C...
Does the user guide tell you should have got this adaptor along with the keyboard? Often there's a "what's in the box" page. They normally do include one.
I would suggest firstly going to Argos and getting a replacement or ask them to supply one. You'll need your receipt.
If not then any universal AC mains adaptor which can supply 12v DC and the correct plug (2.5mm) will do the job.
You should be able to get them from Maplins, Ebay or here's a web site:-
http://www.uk.best-price.com/search/landing/query/Pa+3c+Adapter/s/google/koid/3442910623/
Jan 02, 2011 | Yamaha Full-Size Keyboard
I recently fixed my ashdown head that I now know works. But when I hooked it up to my Randall 4 12 stack I get nothing. What could be the problem with the stack?
If the amp originally failed, it MAY have blown out a circuit protector or fuse in the stack. Check the stack resistance with an ohmmeter. It should probably be around 8 ohms.
Aug 31, 2010 | Randall Rs412xc 4 X 12 Speaker Cabinet
I just purchased a mackie 1604 vlz3 and am trying to figure out where all the parts and wires go to and how do i know if a trs is required or just mono ect... i have a compressor/effects/bbe/wireless mic/...
The user manual has fairly good diagrams.
Get user manual here:
http://www.mackie.com/products/1604vlz3/pdf/1604VLZ3_OM.pdf
On page 34 is the BLOCK layout which has everything you need to know, once you figure how to read it!!!
The Triangle symbols are operational amp/analog summing amps.
By looking at the jack symbols you can tell if they are mono or TRS.
A lot of the TRS ones will show a TRS three lead jack but have a resistor to ground. These can be used as mono's.
The TRS (stands for Tip-Ring-Sleeve) connectors are used in two ways. One is as a balanced input where both the signal and its inverse is used. A balanced line is far more noise free and ground loop free than an unbalanced line.
Another use of the TRS is for external effect insertion where the sleeve is ground and the tip is the signal SENT to the external effect box and the ring is the RETURNed signal from the effect box.
SOMETIMES you may have to make your own cables to get the signals where you want them on the connectors.
HINT: Use XLR connections wherever you can. More rugged, balanced and noise free- ground loop free.
Dec 16, 2009 | Mackie 1604 Vlz3 16 Channel Mixer
I bought an Alesis SR-16 drum machine from an online seller advertised as "new". I plugged it in, and it appears that my "new" machine has had all the factory preset patterns erased! Is there a way to...
Hi.
The SR-16 has 50 preset patterns that are built in, I do not think they can be deleted, if there are no patterns the unit may be defective, even if patterns can be reinstalled using an rmidi file or re-flashing the unit.
To reset an Alesis drum machine you have to hold down both Play and Erase buttons while you power on the machine at the same time.
If that does not work, the presets are held into an rmidi file , the Rmidi file is not available for download. I think it can be purchased contacting Alesis or Rmidi.
I quote from Alesis Rmidi page:
"A rMidi Import/Export File named 'Sr16PresetKits.xml' containing the Sr16 Preset Kits has been installed within the folder named 'Sr16' within the directory in which you installed the rMidi FrameWork software. You can Import these Kits into the rMidi Drums Control if you wish. "
Check if you have the file in the folder.
If not the Sr16 will allows you to export your User Drum patterns, but I do not think you can export factory patterns.
Nov 20, 2009 | Alesis Sr 16 Stereo Drum Machine
Music Logo
1,727 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
