Question about Acer H7350DDLP Full HD Projector
The projector has no sound when i connect it with my xbox by hdmi cable. It's strange because it has worked perfectly before.. And the xbox make sound when i connect to TV. Can you assist me solving this problem? thx
  • 2 more comments
  • balint trunko May 28, 2011
    sorry I missed, I have an acer H7530 pojector with speakers. And the xbox sends the audio and video signs correctly for sure on the hdmi cable.
    volume 100
    mute off
    p vol middle
    a vol middle
    100
    off
    middle
    middle
    yes, blue bar all the way to the right. I confirm 1., and 2. too!
  • 910 Answers
When you say it worked before do you mean with the xbox connected directly to the projector as I can't understand where the sound came from as neither the projector or xbox have speakers?
Posted on May 28, 2011
  • 1 more comment
  • Andy Turner May 28, 2011
    OK, What are the settings in the audio menu? (Volume, Mute, Power On/Off Volume & Alarm Volume)
    By 100 I presume you mean the Blue bar all the way to the right.
    If this is correct then could you please reconnect and confirm 1) The Xbox sound still works when connected to the TV & 2) The TV sound still works when connected to the Projector. Both using the same HDMI Cable that you're currently using to connect your Xbox to the Projector.
    If Xbox to TV & TV to Projector are OK then I can't understand why Xbox to Projector Isn't working. The only suggestion I have is to get a 2nd HDMI Cable and connect Xbox to TV & TV to Projector as you know this works. I still can't understand how it works as all TVs I'm aware of do not put Audio Out through HDMI.
I want to connect my Philips HTS3357 Home Cinema System to my Panasonic PT-AE900E LCD Projector, How do I go about putting it altogether so it works with my xbox360/PS3
Generally speaking, if your Home Cinema system is able to pass-thru video as well as audio, you'll want to take the HDMI cable from the XBOX video out, into the Home Cinema system's input (any HDMI input should be fine), and then run the HDMI video out to your projector. Any other devices you want to be able to project as well (DVD/BluRay, PC, Cable, Satellite, etc.) would also be plugged into the Home Cinema system as "in" devices, like the XBOX.
When you want to display one of those devices, you would select that "in" port's input name in the Home Cinema system (for example, if the XBOX is connected to the HDMI in that is labeled "aux", you will switch the cinema system to Aux Input, and the projector should immediately begin getting the signal from the theatre system. To switch to another device, you simply change the Input channel on the Home Cinema.
The audio also, providing the device (the XBOX) can carry it on the HDMI cable, will also be delivered to the Home Cinema. Some devices cannot carry sound on HDMI (though many can). For those, you will need to run an HDMI cable for the video, and also an optical cable or other type of audio-only cable, for its audio. You do not need to run an audio cable to the projector though, as the projector is only for video. The Home Cinema will take care of the sound itself.
Mar 28, 2014 | Philips HTS3357/05 Theater System
No Sound on LG Super Blu-Ray Disc & HD DVD
Its something wrong in the cables connection try to reconnect them! And make sure that the connection is perfect according to manual then try it. It should work nicely. Moreove HDMI has great sound + picture effect.
Dec 13, 2007 | Televison & Video
Connecting VGA Screen to HDMI laptop
Press and Hold "Fn" and then press number key with "square / square w/ legs (like monitor)" icons
Jun 18, 2013 | Computers & Internet
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Denon 1312 receiver composite video inputs do not work.
I'm having the same problem with my Wii output. The manual for the Denon AVR-1312 says that analog video signals (i.e. component/composite outputs from the Wii) are not converted to digital video signals (i.e. HDMI output from the rcvr). I'm running only HDMI to a projector, so the video signal is essentially lost. The fix appears to be to run an additional composite cable all the way to the projector. Sounds like your fix is the same. No Wii tonight! :(
Jul 07, 2012 | Denon AVR-1312 5.1-Ch A/V Home Theater w/...
I have an Emerson lc320em9 3 model tv and I can't
Make sure your X Box is switched to component and not hdmi.
May 02, 2012 | Emerson Televison & Video
I have an optoma HD20 and it connects using a 1.5m HDMI but as soon as i try a 10m HDMI connection (even with a booster it does not connect) any suggestions welcomed?
Hi kgomer782 I have similar issue. My optoma hd20 signal connection with a 3/6ft hdmi cable is perfect. However, no signal is detected when connected to a 35ft hdmi 1.4 cable. The 35ft cable is indeed working becuase I tested it succesfully when connected to a 1080p HDTV. Did you received any solution to your problem? I wonder if it has anything to do with the HD20 design of the "debossed" hdmi ports that prevents the cable plug from getting completely "seated" in the port? My 35ft cable has a flat square male ending however, the 3/6ft cables have slim male ending that seems to accomodate perfectly in the Optoma's hdmi port design...kaufmanekpr
Aug 07, 2010 | Optoma HD20 DLP Projector
I can't get sound from my HDMI Cable.
check the system settings of your console and make sure everything matches what your tv supports. Also check the tv settings so that it reveives audio from the HDMI cable
Aug 09, 2009 | Yamaha HTR-6130 Receiver
Lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
Your receiver is sensing the video source. Try using optical, or coaxial digital audio for an input, this may work.
May 11, 2009 | Yamaha HTR-6160 Receiver
Bose 38 with a Scientific Atlanta 8300 HD DVR and Epson Projector
The Bose VS2 does not pass the HDMI audio. Must connect analog or digital audio direct to the corresponding audio input on the media center. Also, verify you have loaded laster Console Software revision provided by Bose.
Jan 17, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Acer H7350DDLP Full HD Projector Logo
120 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
