I have a Rheem Loline solar/gas hot water System. there is no hot water only warm. we have a panel in our laundry which I don't know what it's for. you can switch it on and off. I re lit the pilot light in the hot water system but still no hot water. What can I do????
chillmaster
  • 104 Answers
SOURCE: I have a Raypak pool
Usually not the gas valve unless line voltage was applied to it. Millivolt systems are very touchy about connections. First check the output of the millivolt generator (thermopile) the wires for this usually go straight to the gas valve they should be one red and one white usually in a high temp fiber glass sheath. The wires will lead from the gas valve to a rod by the pilot. Test between the two wires with a meter that can read mV DC. You should have somewhere in the neighborhood of 450-600mV DC. If you do not, then the thermopile is bad. If you do, then it is either a bad connection somewhere or an open safety in the circuit. Check all of the safety devices and clean all of the connections in the unit with sandpaper. Usually for safety devices there will be a high limit on the discharge of the header, a pressure switch sensing water pressure, and a rollout switch or two in the control compartment above the burner. Good luck, I have to battle with mV systems all the time at work, usually it's just a bad connection.
Thanks,
Chillmaster
Posted on Jul 03, 2008
  • 85 Answers
SOURCE: GAS WATER HEATER PILOT LIGHT
It could only be the following problems: Therm couple failed, gas valve failed. Therm couple is the cheaper fix it, so it would be your best first try.
Posted on Dec 05, 2008
SOURCE: Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Posted on Jan 06, 2009
  • 30 Answers
SOURCE: Hello! My rheem natural gas-powered
make sure the pilot light stays on. look for a reset button which could be an overheat stat tripped. check to see if the thermostat is set up above the pool temperature.
Posted on Mar 26, 2009
gary1121
  • 332 Answers
SOURCE: Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
Posted on Jun 06, 2009
How long will it take Rheem solar hot water to heat up
read manual:
http://www.rheem.com.au/Assets/1294/1/Rheemsolarlolineelectric511series.pdf
Usually electric element heats about 20 gallons per hour.
It appears the element is controlled by thermostat and automatically kicks ON when tank falls below thermostat set point..
This will be handy since element will continually heat the circulating water when outside temperatures turn cool... of course it will also be wasteful if thermostat is set high.
Jul 11, 2013 | Water Heaters
No hot water
10-22-12
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Tank-type electric:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
Oct 21, 2012 | Rheem Water Heaters
I have a Rheem 120810BD hot water system and BCC won't pass the house cerification unless the hot water is a 4 star rating. Can anyone tell me if the system is 4 star rating? K
1) Call Rheem. I don't know the number outside the US.
1-800-432-8373
2) Contact local plumbing supply and ask who sells the Rheem unit. Then call that dealer and inquire about rating.
Aug 29, 2011 | Rheem Water Heaters
Rheem warrior glass serial num r0296b08705 model
You need to first determine if the burners light or not.
As long as the unit wasn't run with a dry tank the unit should not have been affected by continuous water running, unless it got hot enough to damage the thermocoupler which is an easy replacement. That is the part that your pilot/ignitor warms so that the gas valve will open the gas line to the burners.
Aug 12, 2011 | Rheem Single Water Heater Thermostat
I have a gas Rheem hot water heater.....The flame appears to be on full blast, not just the pilot. I have run no hot water today, so we shouldn't be out of hot water. The water our of the hot faucet...
Sounds like you have cold water entering the hot pipe, or crossover.
(A) Put bucket under water heater overflow pipe, and stand back from scalding water. Gently open and close the TP relief valve on water heater. Check temperature of water to see if heater genuinely has hot water.
It could be the water heater has sediment build-up and is no longer able to heat the water, or the gas thermostat is bad.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
(B) If water heater has hot water, and hot is not getting to faucet, then you have a crossover problem somewhere.
1) This problem can be located at crossover point of a recirculation system, if re-circ check valve has failed.
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) Failure of a single handle faucet cartridge can cause crossover.
Read how to test for crossover:
http://waterheatertimer.org/pdf/Crossover-on-single-handled-faucet.pdf
3) Other causes for crossover are a failed check valve elsewhere in the plumbing system, for example on the pool equipment. Also a failed mixing valve which is usually installed on top of the water heater so that some areas of the house like laundry room receive very hot water, while the kids bathroom receives lower temperature water.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem pronto tankless water heater just barely warm model # 74pvn-1. This is in a house we are just purchasing. Also it looks like it may be attatched to another tank water heater , Help please
Before calling service technician, open following link for Rheem troubleshooting resources.
Sometimes people attach tankless to tank-type heater to preheat incoming cold water.
Additional tanks are also used to store solar heat, and some installations have tank-type because tankless is unreliable. Service technician can sort out the function correctly.
http://waterheatertimer.org/Tempering-tank.html
Owner should read tankless manual thoroughly, especially troubleshoot and maintenance sections. Tankless require yearly maintenance.
Since tankless are expensive to repair and replace, you might be able to fire up the tank-type water heater and provide hot water without much cost.
You can also install tank-type gas water heater yourself. Lowes sells 40 gallon for $317.00, and then you offer 10% less.
http://waterheatertimer/How-to-install-gas-water-heater.html
Apr 19, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Need to replace gas spa heater. Is there a combination gas and solar spaheater
You may actually use any pool heater with a solar water heating array. I do not however know about any that come as a package deal. You will need a solar array, a solar controller, a actuating valve to hook to the solar controller, and a new bypass assembley for the plumbing system. All of this is made by manufacturers such as : Jandy, Pentair, Raypak, Lasco, Buderus, Hayward, etc....
Feb 16, 2011 | Solar Rheem Gas Fired Pool & Spa Heater...
May 22, 2009 | Water Heaters
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
