Question about Daewoo DTQ-19P3FC 19" TV
My Daewoo TV Screen display SVC v1 and nothing else works . what is there to do?? thanks
My Daewoo TV screen just went all Blank n Black suddenly while it was running all fine Then this was accompanied by a strange clicking sound and now whenever i turn it on,it just shows nothing(blank...
The set has developed a short either in the power supply or the horizontal/high voltage circuit. The power supply makes a weird noise when it gets overloaded. This can get complicated so have a repair shop check it out for you. Thanks
Nov 01, 2009 | Daewoo DTQ-13V1FC TV
Daewoo DSL-17DW3 NO RESONSE at all, remote nor manual
There is a problem with these, common to many other badly designed TVs. They get too hot for the capacitors which dry out and cause all sorts of probs.
May 18, 2009 | Daewoo DSL-17DW3 17.1 in. HD-Ready LCD...
There is no image on our screen. The remote control does not work
it is locked.that is why there is a key there.it is a parental lock.
May 13, 2009 | Daewoo Televison & Video
Broken Screen on Plasma TV
Broken Screen on Plasma TV A broken TV screen can not be fixed. A replacement sceen can cost as much as a new tv since the new set prices keep falling. You can sell the unit for parts. (ebay?)
You can get a screen protector from;
http://www.tv-armor.com/
or fashion your own.
May 09, 2009 | Akai LCT3285TA 32 in. LCD Television
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Pd46c10 daewoo plasma
I have a DAEWOO PD46C10 recently it would come on display a beautiful picture play for 10 minutes and the screen would go black.After several minutes reset turn it on and the process starts again.Whats the problem and where can I get it repaired???????????
Nov 25, 2007 | Televison & Video
Problem with my Goodmans 2065TS
Hi.
Sounds like your tv has gone in to service mode.
Try doing this (BUT DO NOT PRESS ANY OTHER BUTTONS)
  • Select pr. number 91
  • Adjust sharpness to minimum and exit all menus.
  • Quickly press the key sequence : RED - GREEN - menu
  • The software version is displayed beside the word Service, e.g. “ SERVICE V1.00A”.
  • To exit SERVICE menu press menu key or Std By key.
  • http://dysonmanuals.inc.io/
    Oct 26, 2007 | Goodmans 2065TS 20" TV
    Daewoo screen in a samsung
    probably not,,,you need to look at the back of the plasma panel itself and see who really made it..the samsung is probably a samsung panel while the daewoo might be from lg..
    Sep 21, 2007 | Televison & Video
    Clock stopped posted at bottom of tv
    In order to remove the Clock display on the TV screen press the DISPLAY button on the remote, it may be labeled OSD on older remotes. As this button may bring up more than one display it may be necessary to press it more than once.
    Jul 13, 2007 | JVC AV-27230 27" TV
    samsung 37 inch plasma screen cracked by my grandson. Can it be fixed
    Jan 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
    Daewoo DTQ-19P3FC 19" TV Logo
    Top Daewoo Televison & Video Experts
     Grubhead
    Grubhead
    Henry  Thomas
    Henry Thomas
    Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
