Question about GE Microwave Ovens
I have a ge microwave and ive tried to unplug it want star, on the display msg panel, when i replug it, it says 8888, and then pf and starts beeping and goes to f-3, can you tell me whats wrong, i have only had it a few months Barbara ward
  • GE Master
  • 9,098 Answers
F3 on a GE / Hotpoint microwave means you have a shorted keypad.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free. GE Customer Service is here.
If it is out of warranty, read on...
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
Samsung microwave displays 8888 beeps then 6666
how can i fix this problem i have an air conditioner whit the same problem and don t work please help me here are very hot
Jun 20, 2012 | Microwave Ovens
Power failure on ge wes1130
Power being interuppted could be anything from a bad fuse , bad fuse holder, bad solder connections on the main board. Bad breaker in your panel. Start by plugging it into an outlet you know is on a different breaker than the on it is on now. See if it does the same thing. If it works ok, then problem with power to the other outlet. If it does the same thing problem inside of unit. PF is Power Failure, now we have to figure out why.
Oct 15, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave has no power
Sounds terminal. Could be the control panel but maybe cheaper to purchase a new microwave.
Jun 26, 2017 | GE JVM1790SK Convection/Microwave Oven
Got code PF and control keypads not working?
Hello :
PF indicates power failure . Displays this message after it has been unplugged or if there has in fact been a power failure .
good luck .
please rate !
Apr 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE microwave started running by it's self. It first said 3.5oz and would not stop until door was opened. then it started beeping and wouldn't stop until door was opened. we unplug hoping it would reset...
It sounds as if you key pad is sticking. PF means that there is an input power problem but could be caused by the sticking keypad.. As far as the unit starting bu itself, the only thing that can cause that is the keypad.. Try running your fingers flat across the panel several times both vertically and horizontally and see if the pad malfunction clears. It will probably repeat in the future but you could get lucky and have a one time instance. The keypad itself is just a bit over $75.00 if it has failed. Good luck.
Dec 10, 2009 | GE JVM1440 Microwave Oven
Display shows 6's across screen & beeps
HI. the touch pad board is malfunctioning at this time. you will need to replace this damaged touch pad device asap. this will fix your issue.
Sep 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
We have a 1986 montgomery ward microwave that the cotrol panel will only display 8888. It appears to be locked.
You can try resetting the micorwave by unplugging it, waiting awhile then plugging it back in. However, considering it's age. It is probably worn out and repair would cost much more than a new mupdated microwave. They are very reasonable in price now.
Aug 01, 2008 | Microwave Ovens
PF ?
Not actually dead, just apparently unresponsive.
PF means power failure. It either got reset or unplugged, etc.
If it's not responding to the keys, then you likely have a shorted keypad or trouble on the control board.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JES1238 Microwave Oven
Microwave stopped working
Sounds like it blew the fuse, and when the fuse blows immediately upon hitting the START button, I'd say you have a shorted high voltage capacitor. But it may also be an open thermal cutout on or near the magnetron or just a fuse. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your actual model number (like JVM1860B01, not XL1800 or Spacemaker) here: http://tinyurl.com/gv383
May 05, 2007 | GE ZMC1095SB 800 Watts Convection /...
Microwave Ovens Logo
153 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
