Question about Plumbing
My sliding shower doors the cord that controlles the 3 panals in the door has come off . I need to replace it
  • 26 Answers
SOURCE: Mazda 5 replacing external handle on sliding door
Your door should be held on with clips. Removing the panel is sometimes hard, just take a good WIDE flat head screwdriver, and whatever tool needed to remove the screws holding the panel on, and be careful. Check underneath the panel, by the inside handle, and the arm point for screws. Once removed, take your WIDE screw driver, and don't quite pry them off, more or less try to get it underneath and pull towards yourself. There is no real easy way, just try to be patient with it, and if you hit any binds, look for more screws, its just a matter of patience for sure.
Posted on Feb 14, 2009
  • 316 Answers
SOURCE: how to remove rear door panal for 03 cts
If you have power windows start by disconnecting your negative battery cable. Then you need to locate and remove the screws that hold your interior door handles in place (they may be hidden by snap in, or snap on clips). Once you remove the screws that hold the door handles, remove any wire connectors to the handles, if they're not power you will need a small hook (kinda like a knitting needle) to remove the window crank. A manual window crank is held in place by a clip on the base. Slide the hook behind the base and remove the clip. The door panel itself, is held on by snap in clips, and you will need a small pry bar to pull them from the door (try to get as close to, or directly under the clips to prevent them from tearing out of the door panel). Once the clips are removed from the door, pull the panel upward to remove it from the door.
Install in reverse.
I hope this helps you, and I wish you luck on your repair.
Posted on May 10, 2009
  • 548 Answers
SOURCE: Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Posted on Aug 27, 2009
Testimonial: "Thanks. I will try tinkering with it a bit more and see if that works better. :-)"
SOURCE: Honda Odyssey 2005 sliding doors won't open, beep 3 times
If you click once your remote control ,will open just driver side doors.To unlock all of them have to press twice , and then sliders.
Posted on Sep 22, 2009
  • 4 Answers
SOURCE: need shower door replacements parts
Supplier in the Netherlands, www.novellini.nl
For the 30095PPC are the next parts:
De benodigde artikelnummers zijn:
1 x R02YOB2G-40 (set scharnieren t.b.v. één deur) à € 23,80 incl. btw.
De prijs van de bovenstaande set onderdelen is € 23,80 incl. btw.
Verzendkosten zijn € 7,50 incl. btw.
Posted on Mar 25, 2010
How do I fix my oden shower door?
ever heard of 2 hammers to pein the rod ends . or even crimp the lower part so it can not slide
Jun 03, 2016 | Home
Sliding shower doors the cord that moves doors need to be replaced
Shower Door cord replacement routing.
Lace cord as shown, leave a bit of slack in the cord before knotting the end. sliding-shower-doors-cord-moves-doors-4aupsgfnj4xszkulrofnusgv-4-0_0.jpeg
Jul 16, 2012 | Plumbing
Where can I find shower door rollers for a maax shower door? Thanks.
amazon is one of the best places for purchasing your shower door rollers. Click here Amazon com shower door rollers and choose the best one (many of them are compatible with maax shower door), but anyway, before order something contact the seller to be sure. There's a plenty of rollers, so take a look.
I hope this was helpful.
enjoy
Mar 05, 2011 | Home
Need installation instructions for sliding shower door...probably #5475. When reinstalling, the inside door is swinging with nothing to secure the bottom.
not sure what you mean when inside door "swings" on a "sliding" door,...i'll assume you need the "inside door guide", a little plastic piece that screws with one screw to the main threshold,.....
Nov 02, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Installing shower doors
you going to need a 2' square aluminum tubing for the corner.
the tubing need to be bolted to the floor. and bolted from the 2 upper rails. then you can attach the doors.
make sure the tube is well secured. the door weights about 12lbs-15lbs each ( depended on the glass).
Mar 22, 2009 | American Standard 5 ft Sliding Shower Door
Door panal
there's a tool to do it . but if your real carefull you can do it without it. 1st remove all the screws on doors armrest , then side a flat head screw drive in between door and panal slide it around till you feel the plastic buttons then pry slowly, repeat till you get them all.
Oct 21, 2008 | 1999 Chevrolet Malibu
Removal of door rt front door panal on a Ford Excersion
make sure to remove any screws or bolts and slide the panel up like when lifting someting and then remove the panel and unlpug any conectors behind the panel if necesary then put it bak the same way
Jun 01, 2008 | 2000 Ford Excursion
Plumbing Logo
287 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
