Question about Mongoose Cycling
Old bike. everything is rusted and the back brakes don't link/work. what's the best way to deal with the rust and at least get the parts moving?
    Guru:
  • 479 Answers
Spray WD40 or other penetrating oil on all moving parts. If you get a syringe from a pharmacy you can put oil into it an squirt it down the shifter and brake cable sleeves. If any moving parts are still stiff, leave the bike for a day to allow the oil to soak and penetrate. Try not to get any oil on the brake pads or rims.
Posted on May 28, 2011
Problem with 2004 bmw 330 CI
It could be rust on the brake disc's , slacken wheel nuts and jack up your car safely and secure with axle stand or stands , remove wheel and inspect brake discs , you will probably find a build up of rust has formed on the edge of the brake disc , firstly get a pair of goggles to protect your eyes , get either old flat file and a good wire brush , clean around the disc , caliper and back plate , once you have cleaned off the excess dirt and rust then put the fille in between the brake caliper and dust cover and hold firm against the brake disc and rotate the disc , this will remove the rust and this needs to be down on all edges ,to remove any high spots of rust this will probably cure your problem this is best done on all brake discs ,
Aug 20, 2014 | Transmission & Drivetrain for BMW 650i...
Wearing brake pads on a 1996 Buick Centry
Stop going to Auto Zone !!!
I have never had one brake issue in 49 years,
of doing my own work
So the answer is-- you have not found a shop or
mechanic, that knows how to work on or diagnose
a brake issues & the best part is- brakes are fairly
easy, no matter what has to be done
I would guess that either side rubber flex brake hose
is restricted & should have been replaced for safety reasons,
when the car was about 12 years old
Add to that- calipers that are rusted inside
Then- never changing brake fluid every 2 years,
more rust inside EVERYTHING
Add-- never removing rust from anything that moves
or slides & never lube anything- because that is what
you get when you pay for brake service
Sep 05, 2013 | Cars & Trucks
My powerwinch brake won't release
you have to conscious of the fact that when dealing with water and equipment running in water there will be a distinct possibility of rusted bits. Winches have a brake system to hold the line in place when stopped so at a guess I would say that the release mechanism is rusted and not working properly. Try spraying in some wd-40 or crc tp see it that helps.
May 15, 2013 | Powerwinch RC30 Trailer Winch
Rust appearing on 10 month old refridgerator doors
How can I put this nicely.
TAKE IT BACK!!!!!! First moisture is forming where it shouldn't, air leak/door gasket not sealing, and second stainless doesn't rust. If rust is forming than it's of poor quality. More iron in it than steel. Isn't there atleast a one year warranty? Don't wait! Till it's too late. Complain NOW!!!
Oct 30, 2012 | KitchenAid Refrigerators
Can you put a rubber line for a rusted break line about 10 in
NO
Have to fabricate a 3/16" brake tubing line &
double flair the ends
You don't do 10",you go back to the last fitting
& remove the complete section,not just cut out the rusted part
Sep 25, 2012 | Chevrolet Cars & Trucks
Need to know how to remove all the brake lines on a 1998 grand am
Just duplicate what is there
Have to buy tubing at auto parts store,
cut,flair & bend to match old ones best you can
I assume you are referring to a line going to
proportioning valve.
If they don't unfasten, just cut then out & remove all
juntion blocks etc,so you can remove the fittings with
them in your vise.
Avoid the ABS System.asumming none of those lines
are rusted
Jun 12, 2012 | 1998 Pontiac Grand Am
My ABS/Brake light in dashboard is on .
I didn't have that issue,but I had a 1992 dakota with
rear abs only & I just unplugged the module under the dash
I'm all for diagnosing everything & having it factory stock & working
But you don't need abs on a 4x4 that old & the rear hydraulic
abs unit ,gets so rusty that it is sad.
If you ever replace rusted brake tubing, remove it
They don't check that in inspection
Jun 06, 2012 | 1999 Dodge Ram
The front door of my side by sde refrigerator is rusting
Go to www.applianceart.com -- These guys specialize in refacing your appliances. Their motto is Don't replace your existing working appliances -- Reface them. They offer magnetic and vinyl options that will fit over the existing surface. I believe the vinyl option will work best for you.
They have solid colors, designs, textures and even stainless steel options.
Worth checking out.
Nov 11, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Srve (p) comes on
That indicates that your Parking Brake is in need
of some type of service.
I'm going to guess you don't disassemble,clean,
and lube any of your brakes once a year,so the
parking brake it's self, may not be the main issue,
that caused your dash light to come on.
I would service your rear brakes,then diagnose
any parking brake issues later, if they still remain
When i say service,I am not referring to replacing
or even machining parts unless necessary.
Brake rust badly in a few months and need constant
rust removal,lube and other attention yearly ,that
unfortunately even the professionals don't do
Apr 22, 2011 | 2003 Lincoln LS
Squeaky brakes
You might try pulling them off and cleaning all the parts with Brakeclean, and pull your pads and put brake lube between every moving part/surface of the brakes, except for between the pads and rotor which you should clean very thourouly with brakeclean.
Oct 21, 2008 | 1995 Dodge Dakota
Cycling Logo
60 people viewed this question
Top Mongoose Cycling Experts
Rommel Balcita
M.R.
M.R.
Level 1 Expert
WTF Chuck.....
WTF Chuck.....
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
