Question about Sony Ericsson K550i Cyber-shot Smartphone
How to remove the phone cover to clean inside screen
Handfree way jumper
Posted on May 23, 2012
Inside of front screen dusty how to remove front screen
unscrew top cover you will find display screen remove it gently and clean it with soft cloth.
Apr 28, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Sir,my display light can't working?m handset no is nokia 1650
Sometimes the backlit gets loose.If there is no light and no image on screen, then you may need to take phone to an electronics store for LCD screen replacement. If there is image, but no light, then:
  1. Power off phone
  2. Remove back cover
  3. Remove battery
  4. Remove SIM
  5. Using a little flat head screwdriver, unlock and remove the frontal cover of the phone.
  6. There are six Torx screwdrivers inside. It's head looks like this:
  1. f85360e.jpgThen use a Torx screwdriver for removing them. If you haven't one, a small triangular file, or a swiss knife will do the job.
  2. After so, remove the back plate of your phone.
  3. Remove the 4 Torx screwdrivers wich hold the screen in place.
  4. Remove the screen.
  5. Clean the contactoes between screen and phone.
  6. Reinstall screen in place.
  7. Repeat steps in inverse order to reassembly the phone.
  8. Power on phone. If light stills refusing to work, then take your phone to an electronics store.
Dec 02, 2009 | Nokia 1650 Cell Phone
How doI take the cover off to clean the inside of the protective screen? sony KP-53v80
I removed about 6 or so screws took back cover off and used a duster to clean the inside screen it cured my cobweb problem.
Sep 12, 2009 | Sony KP-53V80 53" Rear Projection...
Dust inside screen how do i clean ?
HI,
Just took T6 and took out the 4 screws and then carefully pulled off the front cover.Then Remove whole dust from it. But Be careful. Although
the screen cover actualy comes off with ease using a little tool. Nokia have one called the SRT6 and is £8 from here: http://www.phatphones.com/nokia-srt6-phone-opening-tool.htm
Sep 03, 2009 | Nokia N96 Smartphone
I want to remove the screen of my 42" Toshiba TheaterWide to clean the bulbs of dust and the inside. How do I remove the screen to get inside?
there are screws behind the speaker cover-remove them-take out screws along back edges-carefully remove screen(its plexiglass) clean all 3 tubes with a soft cloth -be carefull cleaning screen most liquids will stain it-also clean mirror-reassembly unit
Sep 03, 2009 | Toshiba 42H81 42" Rear Projection...
Looks like I have a couple of flys on the inside of the screen
Dont even think of removing the screen.....virtually impossible to reinstall. If you must clean...clean the picture tubes. Blow the dust off the lenses with air spray, then spray a lint free cloth with a lcd, plasma cleaner. Try not to use windex. [leaves a film on plastic lens] . Now pay close attention because the mirror you try to clean is a reflective plastic sheet that can tear easily. Lightly brush a new feather duster on this. Now you can only do this by removing the lower back cover [a hard cardboard material] and dislocate your elbo to clean . You can clean the inside of screen with the feather duster, donot use a cleaner inside the screen or mirror. Relocate the old elbo and replce the lower back cover.
Aug 25, 2009 | Philips 55PW9363 55" Rear Projection...
Need to remove screen cover
you have to remove the back of the tv to clean the inside screen.
Apr 29, 2009 | Toshiba 57H82 57" Rear Projection...
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Hitachi 53UDX 10B 53in Rear Projection
Steve, easier and safer to remove back panels, remove bottom back cover then remove top back cover, be advised the top cover has a giant mirror on the inside so it will be heavy and easy to break, use 2 people to remove it, this way you can get at the inside and clean the mirror at the same time, hope this helps and Happy New Year, BMW Rider
Dec 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Dirt on the inside screen
Usually the best way is to remove the top back cover and clean the inside of the screen with a clean, dry cloth, but be careful because the mirror is mounted on the inside of the top back cover.
Jun 21, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Sony Ericsson K550i Cyber-shot Smartphone Logo
88 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
