Nomad jukebox3 20GB - 1.20.6 FW Boots when ever power is appied (battery insert, PWR plug-in) than... HANG @ menu. Master reset & complete pwr drain, no change. Started after deleting songs
  • villageid10t Aug 16, 2008
    Cannot reformat unit... Its Hung. Is there any way into the unit i.e button sequence@pwr-on?
    Cannot reformat - Hung
    Cannot reinstall fw - Hung
    Is there any way into the unit using button sequence@ power on etc...?
  • 376 Answers
You could try to reset the player to see if thaat helps you get any further. I think theres a tiny hole on the player which will do this. I think this would be your best shot if you can't reset the Firmware. Hope this helps.
Posted on Aug 16, 2008
  • L Jefferson
    L Jefferson Aug 16, 2008
    So nothing happens when hooked up to a computer?
    Genius:
  • 1,269 Answers
Try to replace the battery. Could be inappropriate power flow. Otherwise, software update is needed.
    Sergeant:
    Champion:
  • 417 Answers
Re install firmware
    Guru:
  • 1,894 Answers
This will need a firmware re installation
  • dewan nafees ahmed Aug 16, 2008
    this is a serious problem in your firmware. and this can be solved when you have the firmware reinstalled or updated.
    please post back the results.
  • 13,433 Answers
Try to format the player, delete all songs on the computer.
  • Ekse Aug 16, 2008
    Have you tried any other firmware versions?
Tip
Car amp wireing pwr cable tips.
Lets start first with running pwr wire. Keep all wires as short as possible to cut down on resistance to the flow of power through the strands. Run the pwr. down the same side as the battery. Drill a hole in the firewall, being careful not to hit any wires or a/c pipes. Insert a rubber grommet into the hole to keep from shorting out wire against chassis. Hide wire in a protected area under carpet, all the way back to ware amp is to be mounted. leave extrea lay and come baec to it.
Now the ground or B - . This is ware most people mess up. Most shops woll screw the GND terminal to metal in the trunk with a 2 foot wire. Wrong.... KEEP THIS ONE AS SHORT AS POSSEBLE. I use a Seat belt bolt and 0awg here. Take seatbelt, or another bolt that is directly connected to frame (unibody in newer cars), and wire brush all the paint off until you see shiny bare metal, bolt back on. when wiering to amp try to keep under 8 -10 " .
Go back to PWR wire, cut off extrea leaving about 10 -12" of slack after hiding wires. connect to amp. Now go to PWR cable under hood. Zip tie wire to secure it from grounding out on manifolds or anything else. you have to install a fuse or circuit breaker as close to the battery as possible not being further than 10" from battery. this ensures if PWR wire shorts out it will blow fusw ot trip breaker rather than catch your wire and vehicle on fire. Remote wire goes to B+ swiched, like blue wire on head unit or an accessory fuse. run RCA's down other side of vehicle to reduec noise. Install fuse. there you are. KEEP ALL WIRES AS SHORT AS POSSIBLE.
on Jul 14, 2010 | Chevrolet Caprice Cars & Trucks
Tip
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
My apple iphone cell phone are locked fore pass code
shut the phone off completely. then when you reboot try holding it's either your camera button then pressing and holding the pwr button as it boots until it takes you into download mode, in which you can do a master reset, but you'll lose everything on your phone... if that doesn't work try the same procedure but with pwr and vol down.
Feb 23, 2014 | Apple iPhone Cell Phones
How make reset factory dell 3110
For the 3100cn, once the web password has been set, you need to do a deep NVRAM reset to clear it.
Before doing anything, print a Printer Settings page so you know what your printer settings are, espcially page count. I might advise dating and saving this for possible future reference
Here's how to deep reset NVram for the 3000/3010/3100cn printers:
1. Pwr Off
2. Hold the Left + Right + Menu buttons while you Pwr-on (release them when display = DIAGNOSING...)
3. At the PASSWORD prompt, press UP, UP, [enter] (enter=center button)
4. Down button to INSTALLATION SET; [enter]
5. Down button to NVM Init; [enter]
6. OK?, [enter]
7. After completion message, Pwr off, wait 5 secs, then pwr on
After pwr on, the LCD displays "Init NVram" & "Initializing", then completes POST with "Diagnosing".
After printer completes POST, the toner level indicators on the LCD may show empty. The printer will need to be Pwr'd Off/On once again to correct display.
The procedure for the 3110cn is nearly identical. Let me know if you have problems figuring it out.
Jan 02, 2012 | Dell 3110cn Laser Printer
I forgot the code
this is all lg hard reset code you much enter it
LG
2945#*# - service menu (code reset)(W3000 G5300 C1200 G7100...)
2945#(*)- hold (LG 500,600)
B1200 *+pwr, 6,6,8 Service Menu
B1300 *+pwr, 1,5,9 Service Menu
Security Removing Code For Lg 8110,8120.
47328545454#
Or
277634#*#
LG
47328545454#
Or
277634#*#
U8180 old ...............49857465454#
U8180 new .............492662464663#
U8330 ...................637664#*#
U8360 ...................*6*41*12##
U8380 ...................525252#*#
ALL LG 2G : 2945#*#
8110 & 8120 : 277634#*#
U8130 & U8138 : 47328545454#
8180 old sw : 49857465454#
8180 new sw : 492662464663#
8330 : 637664#*#
8360 : *6*41*12##
8380 : 525252#*#
LG 8550 885508428679#*#
Phone
Service Menu Code
8110 277634#*#
8120 277634#*#
8130 47328545454#
8138 47328545454#
8180 v10A 49857465454#
8180 v11A 492662464663#
8330 637664#*#
8360 *6*41*12##
8380 525252#*#
Phone
Unlock Menu Code
Older phones 2945#*88110#
U880
was told that unlocking code for the phone is "0794070061"
and method is to enter 142358#*#
but when i enter above code instead of asking for nck code it restarts(phone is temporary unlocked with sim inside).
Plz help how to unlock it permanently
Mar 03, 2011 | LG Dare VX9700 Cell Phone
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
Magellan Explorist 500 LE Power
eXplorist units have also some hidden and service functions. Like, if unit is off, you can to press:
- IN + PWR - to full selftest of unit (screen test, keypad test, NMEA test)
- OUT + PWR - to serial port test
- ESC + PWR - to burn-in process
- LIGHT + ENTER + RWR - tp uploading of new firmware
- NAV + PWR - to call Service Function window (see below)
- NAV + MENU + PWR - to force power off, equal remove batteries.
- GOTO + OUT + POWER - clear memory and set all settings as default.
IN + PWR helped to power up my unit.
Feb 24, 2008 | Magellan eXplorist 500 GPS Receiver
52 people viewed this question
 Grubhead
Grubhead
