Question about Microsoft Windows XP Home Edition
Have only realtec audia manager but can find my normal volume botton anymore on my home pc
    Scholar:
  • 86 Answers
Go to Start > Control Paned > Sounds and Audio Devices > Volume (Tab)
Check the box which says "Place the Volume icon in the Taskbar".
If this option is grayed and you can't place a tick on it then it means your Realtec Audio Driver needs to be re-installed properly.
Posted on May 28, 2011
  • 519 Answers
Hi Tania,
This problem is a 'bug' in Windows XP operating system.
Follow these steps to restore your volume button:
  • Click on 'start' & select 'Control panel' from the menu.
  • Look for the icon named 'sound' in your control panel & click on this icon to open sound properties.
  • Look for the check box with the words: "Show volume control in task bar"
  • Remove the check from the check box & click on the "apply" button at the bottom right of the properties window.
  • Now click on the check box once more to add the check once again.
  • Apply the change by clicking "Ok" at the bottom of the properties window.
Your volume control should now be visible once again in your task bar.
Don't hesitate to respond should you have any further queries.
Best wishes,
Graemevm
DVD player dp313 volume problem
try to clearn the (-v) botton ,this can be due to moisture inside the botton
Apr 26, 2012 | Norcent Technologies DP313 DVD Player
We bought a samsung tv off display and the tv is on store mode and we do not have the remote to change it.
frist turn on tv
press the menu botton
press the channel donw botton to go to setup
on setup press the volume +
press the volume botton again
press the source botton to enter in the plug and play option
press source botton and select store or home by pressing the volume botton
and then press the source botton again
after this just turn ur tv off and than on
Nov 30, 2010 | Samsung TV Remote Control
My audia s not working from backside, wht will b the problem
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 23, 2010 | PC Chips P25G Motherboard
THERE IS NO SOUND TO MY PC
Please check in your taskbar if the sound hasn't been muted and thus turn up the volume to middle.
If that is unavailable please download, extract and install the following(Please choose your Operating system)...
Realtec Sound Driver VISTA
Realtec Sound Driver XP
May 24, 2010 | Acer Aspire 5500 5570-2609 Laptop
Hi,after i reformatted my windows xp..the sound did not come back even i can see on device manager that the sounds was properly installed....i tried my speaker to other pc it worked...but to this pc where...
Ok, let's try this first: Start-Control Panel-go on sound icon and double-click on the icon. On the volume tab click on the advanced button and select what kind of speaker are connected to the pc, make sure to plug your speaker correctly on the back of your computer. and give me the result for this firs attempt.
Apr 22, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Very low speaker volume with all controls maxed
Problem solved... It's embarrassing to report actually. The A3 has a manual volume control knob which sits quite inconspicuous at the front RH side of the case. Just never noticed it...
Apr 17, 2009 | Toshiba Tecra A3 Notebook
Repairing it
Get the updated version of the Device Manager from Philips website, and THEN run the repair. If your PC isn't recognizing the device, a normal repair is hard to do, so you have to follow my bootleg instructions:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Jan 09, 2009 | Philips SA3025/37 Flash MP3 Player
Logitech g51
I'm sure you went to Control Panel, opened device manager, and and checkeck for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external. Did you forget?
Nov 08, 2007 | Audio Players & Recorders
Cannot seem to calibrate.
Go to Control Panel, open device manager, and and check for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external manually. You can adjust volume there..
Oct 05, 2007 | Logitech Z-5300 Computer Speakers
Microsoft Windows XP Home Edition Logo
87 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
