Question about Rocky Outdoor Gear Rocky Mountain Trailhead Mtb Mtn Bike Bicycle 18" 08
Describe the chain run on shimano gears - Rocky Outdoor Gear Rocky Mountain Trailhead Mtb Mtn Bike Bicycle 18" 08
    Brigadier General:
  • 8,546 Answers
Can I replace a Shimano RD-TY15 with a Shimano Tourney TX?
This may be to do with the replacement having a shorter cage, so it can't go on the big sprocket and big chain ring at the same time.
Try to not use the big rear sproket and the the big front chaining at at the same time,
Apr 24, 2015 | Shimano Cycling
How to replace front cable shimano comfort 050 ?
Put the bike in the lowest numbered gear, put chain on smallest spocket/chainring. Disconnect cable from derailuer, pull cable, then replace with a new one by following steps in reverse. For detailed pictures, go to Utube or sheltonbrown .com.
Sep 01, 2014 | Shimano Cycling
Adjust cycle gears
Chain shifter or derailleur is improperly adjusted. Take to nearest bike shop for service
Aug 05, 2014 | Shimano Ultegra BB-6500
My shimano ultegra left shifter is super stiff/hard to push in; what is going on?
Try flushing out the shifter(s) with WD-40, use plenty. The next step will be replacing the shift cables and cable housings.
  • Take the bicycle in an area free of cars and obstacles, such as an open parking lot. Concentration is required when learning to use Ultegra shifters or any other type of bicycle shifter.
  • 2 Mount the bicycle and rest both hands on the proper Ultegra hand control. The left-hand control operates the front derailleur. The right-hand control operates the rear derailleur.
  • 3 Start pedaling, smoothly and evenly. While pedaling is crucial to propelling the bicycle forward, it is also necessary when shifting the derailleur. Pedaling forces the chain to rotate. The chain must rotate before it can transfer to another gear.
  • 4 Push the outside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a smaller rear gear.
  • 5 Push the inside right Shimano Ultegra lever in toward the bicycle. The rear derailleur will shift the chain to a larger rear gear.
Rear Ultegra Derailleur Control
  • 1 Push the outside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to larger front gear.
  • 2 Push the inside left Shimano Ultegra lever in toward the bicycle. The front derailleur will shift the chain to a smaller front gear.
  • 3 Use the front and rear Ultregra hand controls interchangeably. For small changes in gearing, using the rear control. For larger changes, choose the front control. A smaller gear causes the bicycle to travel a shorter distance per pedal stroke but also requires less energy to use. A larger gear requires greater effort but in turn causes the bicycle to travel farther per pedal stroke.
Oct 25, 2011 | Cycling
How do i put the chain back on a 18 gear shimano mountain bike
Hi emg350...
You will loosen the axle nuts on both sides of the rear axle and then route the chain as shown in the picture below at this webpage..
After you have the chain reinstalled, then you will retighten the axle nuts.
Please take time to rate me
http://www.bing.com/images/search?q=rounting+of+a+shimano+gear+chain+picture&view=detail&id=CDD212FEBCEA790DF540791E08538D05D592EA3D&first=30&qpvt=rounting+of+a+shimano+gear+chain+picture&FORM=IDFRIR
Sep 14, 2011 | Cycling
Just taken ownership of mountain bike with 18 speed shimano gears. Bike has been in a garage for some time unused. Front gearing working okay. Have oiled chain and sprayed deraillieur with WD40 but the...
Cables get all rusted inside and if they don't slide smoothly on the release of shifter tension your upshifts will be sluggish at best.
Here is a source of a lot of good advice plus they make the best tools for getting the job done.
http://www.parktool.com/blog/repair-help
This wise cyclist left us a wealth of great material.
http://sheldonbrown.com/chains.html
The web has all sorts of good advice, much in video form, if you just search for it. Like "how to shift".
Sep 01, 2011 | Shimano Cycling
Good day guys, i would like to ask if it is possible to repair the "shimano dura ace cs-7900" and those other shimano rear speed sprocket? because my speed gear wasn't working. thanks guys.....
What's not working about it? It has NO MOVING parts.
You can find details for it and everything Shimano at http://techdocs.shimano.com/techdocs/index.jsp
Chain issues maybe?
Derailleur adjustment? Get focused in if you want specific help.
This resource covers a lot...
Search engines "how to..." also find a lot of procedures in video form.
Jul 14, 2011 | Shimano Dura Ace CS-7900
Hi. I've had this problem before and it's infuriating. I've renewed my Chain wheel, Chain,and 8 speed cassette. It works fine on the stand. However when road testing I find that in either of the front 3...
Try using a Shimano hyperglide chain. I know they are more expensive but they fit better. The reason is the angle that the teeth of the cogs and gears are machined at. The idler wheels should be replaced too if you think they are worn. Also make sure that the tension spring in the derailleur is getting weak. They can be replaced with a little work. Here's some sites with info that will help:http://www.parktool.com/repair/byregion.asp?catid=5 Also:http://sheldonbrown.com/harris/tools.html Please let me know if this helped.
Nov 19, 2009 | Cycling
I have a shimano tourney deraileur with sis index. what does the small adjustable screw which is off by itself adjust. the other two screws are for the upper and lower gear stops.
Is it a long screw running into the derailleur hanger? This sets the distance from the cassette to the jockey wheel. You use it to pull the jockey wheel away from the large cassette cog if the chain is having trouble clearing it. You'll know if it is happening because the bike will be making more noise in the low gear and it will sometimes want to skip out of gear.
Sep 13, 2009 | Shimano Cycling
Rocky Outdoor Gear Rocky Mountain Trailhead Mtb Mtn Bike Bicycle 18" 08 Logo
95 people viewed this question
Top Rocky Outdoor Gear Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Rocky Outdoor Gear Cycling Expert? Answer questions, earn points and help others
