Question about Sony Computers & Internet
I just bought a 2xspeed USB floppy disk drive, but my computer cannot op the driver CD that came with it. Michael Payne
    Genius:
  • 1,269 Answers
I believe you don't need to install the driver that came with it. I assume your Operating System is Win XP and it has a default driver for your usb floppy disk drive. That will automatically be installed.
If you want to install the driver that came with the CD, try to copy the whole files from the disk and paste it to your hard drive then run it from there.
Posted on Aug 16, 2008
  • Sony Master
  • 13,433 Answers
The drive should show up in your computer, most likely as the B: drive and no driver shouldn't be required.
  • Ekse Aug 16, 2008
    whats the brand and model of this floppy drive?
  • Sony Master
  • 19,396 Answers
Check that the CD is not damaged or dirty.
  • Ginko
    Ginko Aug 16, 2008
    Check that the CD is not damaged or dirty, even if new. Check that your CD driver lens are not dirty using a CD cleaner.
    If you cannot open the CD at all, then the CD provided with the device it is probably faulty.
    When this happens you have two choices, either ask a replacement to seller or download a copy of drivers from factory.
    My suggestion is:
    First post here model number, we can see if there is any download available for your unit.
    After ask a replacement cd to seller, you may need it in the future.
    By the way the CD provided is for Win 98, Win ME or older, if you have Vista or Windows XP you do not need to install any software to install an USB floppy unit.
    Therefore, if you can open the CD but software does not install this is perfectly normal.
I have floppy disk for all software can I get it on cd?
best solution would be to go on ebay and buy a usb floppy drive, that way you can still use and open the floppies. either that or buy the floppy drive and fit it into the computer.
most laptops and desktops support usb floppy drives
they quite cheap too. good luck
Jun 16, 2012 | Husqvarna Rose
Citizen x1de-usb
If you have the disk... The drivers will still not install correctly using the usual method. Do this: Go to the system applet and find the yellow flag indicating the device is not installed correctly. Click on it and go to the box that says "Update the drivers". Put the disk in your CD/DVD drive and "kill" the inquiry box that comes up. Now tell device manager to find the drivers on your computer and point it to the CD drive. Click Install and they will install fine. You wont even have to re-boot probably.
Dec 12, 2011 | Iomega BXXU0130 144MB USB Floppy Disk...
I have a SmartDisk External USB 3.5" 1.44MB Floppy
well you I&hash39; have got problems the first thing i would be looking for would be a bad driver to this device if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if the problem still persists check the leads that attach to this device make sure they have secure seatings or just replace them they could be faulty from overstreching
hope this helps
Apr 14, 2011 | SmartDisk USB Floppy Drive Titanium...
I have a manhattan 700856 usb floppy drive and i need a driver that is compatable with windows 7. i need the floppy working so that i can fix a laptop and the only way is with this floppy and i need to...
Hello there
Alot of times if you search bootdisk.com there is a lot of disks downloads for floppies that may help you
Also if you Google this product and use the download after the product name you may be able to find it there ok
Hope this helps you out
Best regards Michael
Feb 23, 2011 | Manhattan External Slim USB Floppy Disk...
Bought this New Dell Internal / External USB Floppy Drive 1.44Mb
Hello there
you will need to check the way the device reads the disk if may have changed if you tried using a ordinary dvd then went a dvd/r some times you need to change the settings back to the way it was when you installed it ok
best regards mike
Aug 05, 2009 | Dell 1.44 MB USB Floppy Drive (1y513)...
We want to install win Xp in Toshiba Satallite A205-S5825
Depending on the model of your Toshiba, it may have an unsupported hard disk controller which requires that you load a disk driver from a floppy disk by pressing F6 when prompted during the boot of an XP installation CD. If so, you will need to download the apropriate driver and put it on floppy diskette, Of course a floppy drive will also have to be available during the boot. (enable USB legacy support in BIOS if you use a USB floppy drive)
Alternatively, check your BIOS settings to see if the disk controller can be set to operate in ATA mode rather than AHCI mode. ATA mode should work with the XP cd-rom.
Dec 06, 2008 | Toshiba PA1381U-1ETC Consumer Headphones
Need a USB converter for some serial thing
dynex puts out a usb to serial adapter can be bought at best buy for somewhere around 15.00 you will need the drivers from the cd to make it work and then will probably have to set the port it is looking for that should be all you need
Dec 05, 2008 | Toshiba - Floppy disk drive - external -...
Can't open the CD driver disk
dear,
install the driver through other souce like cd or download it throuhg net it will not heavy ...
regards,
dont forget to rate it dear
Aug 16, 2008 | Computers & Internet
Samsung USB floppy disk drive won't work without the CD-ROM device driver...
Here http://www.fixya.com/support/r6260295-samsung_sfd_321u_drivers
You will find SAMSUNG SFD 321U DRIVERS For windows above.
Jun 29, 2008 | Computers & Internet
Bought a usb floppy drive reader to convert my floppies to my laptop. have plugged in the usb cord. what do I do now?
Its easy to use:
Step 1). Just on your lap.
After complete boot
Step2). Insert your floppy connector one end to your USB port of Lap.
Step 3). Double Click on My Computer Icon.
The my Computer will be open.
and if every thing is ok, a floppy disk drive icon [A: or B:] will be shown in the window.
Step 4). Insert your floppy disk into the Drive.
wait till the floppy disk drive light goes off.
Step 5). Double click on floppy disk drive icon [A: or B:].
and the content of the floppy will be open.
have any question... ask me
Thanks
Iqbal
Mar 22, 2008 | Computers & Internet
Computers & Internet Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
